Lotus Elan
ZF S5-18/3 Transmission
PostPost by: Ianashdown57 » Wed Jan 21, 2015 2:29 am
Having recently pulled the plug on my BDA/5-Speed Elan project I have a few parts that I acquired that I no longer have need of. One of them is a ZF S5-18/3 Transmission. This was bought from Michael (cant remember his last name) in Florida who specializes in selling these transmissions and parts for them. It has the short shifter extension and selector rods with it, although not fitted. This put the gear lever in almost the perfect spot for an Elan - well at least better than any other non-original transmission.
This is not the CR one but the one with the OD 5th gears. Ratios are:
1st 2.99
2nd 1.76
3rd 1.30
4th 1
5th 0.874
It is in very nice condition and given that these were designed for much more than Elan HP should be absolutely bullet proof!
$3500 OBO
Shipping at buyers expense
Ian
SoCal
Ianashdown57
PostPost by: everettmse » Wed Jan 21, 2015 6:52 pm
Hi Ian,
PM Sent
everettmse
New-tral
PostPost by: DJ908 » Wed Jan 21, 2015 7:12 pm
The ZF S5-18/3 gearbox you have here is the standard box fitted into the type 81 Lotus, a Sunbeam Lotus. There are several different sets of ratios available for this gearbox.
It is a reasonably common gearbox found in several different European cars. Originally designed, I believe, for the light commercial vehicle market.
Robert
DJ908
First Gear
First Gear
PostPost by: holywood3645 » Thu Jan 22, 2015 6:25 am
These are very popular box also suitable for 'historic' MK1 and Mk2 escort. Different gear sets are availiable with CR gear set and 1:1 top, They are an excellent choice for an elan because of the overdrive 5th.(as in this gear set, and simple fit)
They are not that at all common, and in Hi demand by the escort boys. A CR version fetches in the region of $8000+
James
PostPost by: msd1107 » Thu Jan 22, 2015 6:26 pm
http://www.eliteracingtransmissions.com ... f-s5-18-3/
http://www.ebay.com/itm/ZF-S-5-18-3-syn ... 0969018977
Might be a suitable alternative to a T9 with BGH gear set.
David
1968 36/7988
msd1107
PostPost by: Ianashdown57 » Mon Jan 26, 2015 4:19 pm
I'm open to sensible offers . . .
Ian
Ianashdown57
PostPost by: vstibbard » Sat Sep 02, 2017 7:03 am
Did you sell the ZF box?
V
PostPost by: holywood3645 » Sat Sep 02, 2017 7:31 am
Ian still has one. I'm seeing him soon.
I have 2, a CR 1:1 5th and WR .87 5th
PostPost by: holywood3645 » Sat Sep 02, 2017 7:32 am
PostPost by: gav » Sun Sep 03, 2017 11:45 am
Wish it was in the UK - I have an overdrive ZF box for my competition car and would love one for my road car too - the ratios are really good.
Gavin
gav
PostPost by: The Veg » Sun Sep 03, 2017 6:28 pm
I wish I could afford it, as I suspect that I'll want a fifth gear eventually.
1969/70 Elan Plus 2 (not S) 50/2036
The Veg
PostPost by: holywood3645 » Sun Sep 03, 2017 6:34 pm
Rob Walker
Prezoom!
PostPost by: Davidb » Mon Sep 04, 2017 2:19 am
Nice box, I fitted one to my Aston DB2 that I recently sold. Mine came from an Alfa Montreal and judging by the ratios, so did this one. The fifth gear at 0.874 is not very useful but, the gears press on and off the laygear so they can be changed. I fitted a 0.8 pair and it worked well. The only weak point I discovered after overshooting a turning in a rally, I braked to a halt, slammed it into reverse, backed up to the turning and continued on the correct course. Don't do this with one of these boxes! (The slamming into reverse bit-not the rest). The reverse gear idler shaft and bearing are not strong. I subsequently learned that ZF recommends replacing them at every opportunity.
Otherwise the box is very nice, fairly tricky to overhaul compared to our wonderful Ford box. It is the box that Lotus should have fitted to the Plus 2 but were too cheap!!
'65 S2 4844
PostPost by: holywood3645 » Wed Sep 06, 2017 6:42 pm
Here is a excel cross reference ratio table of some of the Gear Boxed spoke about here. Please edit and add additional info you have.
I'm getting fed up looking all over the place for the relevant info and figured i would consolidate.
James
I will open a new post with the excel file available for edit & save
Link to post
lotus-talk-f50/gearbox-cross-ref-types-ratios-etc-open-for-editing-t40227.html
gb-capture.jpg and
PostPost by: lotus looker » Sat Sep 09, 2017 7:45 am
DJ908 wrote:The ZF S5-18/3 gearbox you have here is the standard box fitted into the type 81 Lotus, a Sunbeam Lotus. There are several different sets of ratios available for this gearbox.
Robert
Believe that the "ZF S5-18/3" is NOT the gearbox fitted into the type 81 Lotus....
Category Formula One
Constructor Lotus
Predecessor 80
Successor 86 / 87 / 88
Technical specifications
Chassis Aluminium monocoque
Suspension (front) Double wishbones, coil springs over dampers, anti-roll bar
Suspension (rear) Double wishbones, coil springs over dampers, anti-roll bar
Length 4,623 mm (182.0 in)
Width 2,134 mm (84.0 in)
Height 965 mm (38.0 in)
Axle track Front: 1,700 mm (67 in)
Rear: 1,638 mm (64.5 in)
Wheelbase 2,789 mm (109.8 in)
Engine Ford Cosworth DFV, 2,993 cc (182.6 cu in), 90? V8, NA, mid-engine, longitudinally mounted
Transmission Hewland FGA 400 5-speed manual
Weight 580 kg (1,280 lb)
Fuel Essex
lotus looker
Next
