Lotus Elan
Twin Cam Parts & Semi Close 2821 Gearbox
PostPost by: casalunge » Thu Aug 28, 2014 12:37 pm
The following are surplus to my requirements
PM or [email protected]" target="_blank" target="_blank" target="_blank" target="_blank" target="_blank" target="_blank
Sump 4 Bolt - SOLD
Crank Seal Housing 4 Bolt
New Old Stock Jackshaft 109E
Jackshaft thrust plate,locking tabs &Sprocket
105E 7505B Bell Housing
Starter Motor Pinion Cover
105E 6752B Dipstick - SOLD
Water Pump Pulley
Alternator Bracket SOLD
New Solid Competition Engine Mount
Starter Motor M35G-1 25147 ?lan Sprint
Dynamo C40 22700 ?lan S1 - S3
Semi Close Ratio Gearbox 2821 internals - SOLD
1960 Lotus Seven Series 2
image.jpg and
image.jpg and
image.jpg and
1960 Lotus 18 FJ
1962 Lotus 22 FJ
casalunge
Location: Halnaker, West Sussex UK OR Volterra,Tuscany.Italy
PostPost by: pharriso » Thu Aug 28, 2014 3:21 pm
Colin, I assume that the brick s**t house Alternator bracket is for a RHD car?
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: casalunge » Fri Aug 29, 2014 10:45 am
Phil
I 'be never seen one different in dimensions to this.
I did encounter a similar issue with my LHD Seven with the proximity of the dynamo to the steering column. A shorter fan belt did the trick.
Best
Colin
1960 Lotus 18 FJ
1962 Lotus 22 FJ
casalunge
PostPost by: RichardHawkins » Fri Aug 29, 2014 8:00 pm
Colin,
Do you still have the alternator bracket? If so how much do you want for it?
Richard Hawkins
RichardHawkins
PostPost by: casalunge » Fri Aug 29, 2014 10:54 pm
Provisionally sold. I'll get back to you if that changes
Best
Colin
1960 Lotus 18 FJ
1962 Lotus 22 FJ
casalunge
PostPost by: RichardHawkins » Sat Aug 30, 2014 7:54 pm
Colin,
Richard Hawkins
RichardHawkins
Users browsing this forum: velo5338 and 5 guests
