Lotus Elan
Advice please - reasonable pricing Plus 2 chassis, diff etc
PostPost by: dunclentdr » Mon Aug 18, 2014 9:14 pm
I have a few 'large' parts left over and would like to offer them at sensible prices to members.
Uncertain as to what 'sensible' prices might be - can anyone advise me so I can list them?
The parts are (All for Plus 2):-
Spyder chassis - early chassis in very good condition, has had a clean and coat of paint, some minor surface rust only, new brake lines in
Diff - has had new output bearings, seals and torque rods and new rubber set, cleaned
Rear brake calipers - need full refurb
2 knock on rear hubs
2 rear uprights
Thanks in advance.
David
David Rose
1963 S1 - Bourne bodied
1965 S2
1966 S3
1969 Europa - 210bbhp by Banks
dunclentdr
PostPost by: Elanintheforest » Tue Aug 19, 2014 6:13 am
I would think that ?500 for the chassis would be reasonable. It may seem a little low, but the holes drilled for the previous car will possibly have to be plug welded and re-tapped to fit onto another car.
This differential would be around ?250 - ?300 if the aluminium casting is very good.
Rear calipers, if they have the handbrake linkages, are quite hard to find, and ?150 - ?200 would be about right..
The uprights, if Type 18 and with good lower castings, would be around ?120, and I would throw in the +2 hubs for that....they are not worth much on their own!
PostPost by: PaulFinch » Tue Aug 19, 2014 8:18 am
David - I've sent you a PM.
Regards.
PaulFinch
PostPost by: LaikaTheDog » Thu Sep 04, 2014 6:51 am
david,
sent you a pm re above
regds
J
LaikaTheDog
Users browsing this forum: snowyelan and 9 guests
