Lotus Elan
Elan Plus 2 Parts Clearout - UK
PostPost by: Elanintheforest » Wed Mar 26, 2014 8:17 pm
Having sold most of my project cars (still have an S4 to renovate, an S3 to refresh and a Plus 2 to re-chassis!) I'm now working into the depths of the barn and garage, and have come up with quite a few Plus 2 bits and pieces that will be of more use to others than to me.
Here is a taster, with suggested (!) prices. There will be more over the coming weeks, but of course if you come over to buy stuff, you will also get first go on what's in the un-opened boxes!
Bonnet with metal frame (flat no stromberg bulge) ?45
Boot lid ?20
Headlamp pods ?30 pair
SOLDHeadlamps with buckets, rims and tails ?20
Passenger door (bare) ?20
SOLDEarly fixed seats ?100 pair
SOLDSeat runners ?30 pair
SOLDEarly rear seat (two cushions, 1 full back) ?70
SOLDEarly door trim panels, grotty but with metal bar ? free
SOLDEarly rear trim panels need re-trimming, good fibreglass ?10 pair
GONEEarly rear parcel shelf, grotty but with metal bits ? free
Rear glass with chip in corner (can't see when inside rubber trim) ? free
GONEEarly center console lid / gear lever trim ? free
Early rear metal frame which holds boot lock (hard to find) ?40
Complete bootlock (fits S3 and Elite as well) ?60
SOLD Oatmeal door trims from S130, good with no speaker holes - ?40 pair
SOLDSet of headlining rods ?35
Petrol tank, small surface rust on outside, still with 'pressure tested' stencilled writing, complete with sender, drain bolt and pipe bolt - ?55
Petrol tank, more surface rust on outside, complete with sender, drain bolt and pipe bolt - ?35
Early heater box, complete but a lot of surface rust ?20
Late heater box with fibreglass side ducts in very good condition ?80
Early steering column (non collapsible) with brackets and early handbrake attached, some surface rust - ?100
Late steering column (collapsible) with shroud, indicator switch - ?100
SOLD Late dashboard complete with all switches, speedo and tacho, and wiring - ?250
SOLDAmbient temperature gauge from 130S that actually works! ?150
SOLDSet 4 knock-on Wolfrace wheels with steel centre rings (wheels need polishing) ?160 the set
Set 5 knock-on early 5.5 J steels (need refurb) look great on the S4 / Sprint as well! ?120 the set
SOLDSet of spinners for refurbishing ?50
Set of 8 front wishbones ?80
Pair of rear wishbones ?80
SOLDSingle rear wishbone ?40
SOLDLate pedal box with master cylinders, pedals and rods - ?65
SOLD Wiper Motor ?10
SOLD Plenum Chamber and Aeroflow Grilles (x4, handed) ?20
SOLD Differential with good casing, output shafts and rods ?250
The next few bits are expensive as this is what I had to pay for them years ago!....
SOLDVery early and first 'S' cars chrome metal trim front windscreen surround with rubber (same as early Capri) - ?150
SOLD Rear bumper, original and in very good condition. Need re-chroming for perfection - ?200.
SOLDFront bumper original and in very good condition. Need re-chroming for perfection ?100
SOLDAir intake 'moustache' in 2 pieces in very good condition - ?150
SOLD Air intake 'moustache' in one piece, new old stock Anglia Van, ?170 (note this is how all Elan moustaches came into being!)
SOLD, Sill chromes, some dinks which could be taken out - ?30 pair
SOLDRoof gutters, early brass and chrome, need to be re-chromed - ?40
SOLDDoor waist trims ?25 pair
SOLDPair of front side / indicator lights, very good, ?160 (with free rear lights, rough!)
SOLDNew dash for early car - light burr walnut ?100
There will be more bits and pieces as I go through the boxes amassed over the years, If you have a Plus 2, are restoring one (or plan to), come over and have a look and get some spare bits. Free gifts for multiple buys!
Most of these things are too big to post so you will have to come over anyway. I'm a few miles west of Gloucester, about 1 hour from Birmingham, Bristol and Cardiff, and 2 hours from London and Manchester.
Last edited by Elanintheforest on Fri Apr 25, 2014 6:48 am, edited 19 times in total.
PostPost by: draenog » Wed Mar 26, 2014 8:57 pm
I'm interested in the air intake moustache (150), and the sill trim. I'm based in Chepstow so easy to pick up from the Forest (where I'm originally from).
Rob.
draenog
PostPost by: Mark plus 2 cabby » Wed Mar 26, 2014 9:02 pm
Hi mark pm sent. Thanks. Mark
Mark plus 2 cabby
New-tral
PostPost by: theelanman » Thu Mar 27, 2014 10:36 am
also PM sent...
thanks
G
theelanman
PostPost by: Elanintheforest » Thu Mar 27, 2014 10:41 am
We crossed in the post Gareth!
PostPost by: DavidLB » Thu Mar 27, 2014 1:37 pm
Hi Mark would be interested in the ambient gauge. Over in hereford so can collect but abroad till end of next week
Regards David Beresford
DavidLB
PostPost by: Elanintheforest » Thu Mar 27, 2014 2:09 pm
No problems David...I'll reserve it for you.
PostPost by: lotusblackbird » Thu Mar 27, 2014 7:13 pm
Hi I am interested in the bonnet you have. What is the condition and can you post to Aberdeen. If you can how much would it be.
Regards Graham
lotusblackbird
New-tral
PostPost by: Elanintheforest » Thu Mar 27, 2014 9:53 pm
Too big to post Graham, and would need to be boxed / crated to avoid getting stress cracks with loads of parcels being thrown on it.
I'm happy to hold it for a while if you're headed down this way in the next few months, but sending it is just too much hassle.
PostPost by: lotusblackbird » Thu Mar 27, 2014 10:16 pm
Hi Mark
I am up in Aberdeen and it is to far travel. Thanks anyway but will have to pass on it as I am unlikely the be in your area.
Best Regards Graham
lotusblackbird
New-tral
PostPost by: rgh0 » Thu Mar 27, 2014 10:41 pm
I love the perception of distance in the Uk. Here we would go that far for a cup of coffee :lol:
PostPost by: lotusblackbird » Thu Mar 27, 2014 10:48 pm
If you are willing to travel nearly a 1000 miles for a cup of coffee. The waitress must be nice
Graham
lotusblackbird
New-tral
PostPost by: rgh0 » Thu Mar 27, 2014 10:55 pm
Maybe i was exagerating a little but I do know a few nice waitresses :D
PostPost by: PeterK » Fri Mar 28, 2014 6:55 am
We need photos Rohan !
PeterK
PostPost by: KevJ+2 » Sat Mar 29, 2014 11:56 am
Hi Mark, PM sent,
Kev.
KevJ+2
Next
