Lotus Elan
Replacement arial
PostPost by: SteveC » Fri Jan 25, 2013 6:16 pm
I damaged my arial when trying to remove it to adjust it.
Does anyone know where I'll get a replacement or for how much?
What would your thoughts be about just glossing over the hole and doing away with it?
SteveC
First Gear
First Gear
PostPost by: billwill » Sat Jan 26, 2013 12:39 am
Yobbos often seem to delight in breaking off aerials, so If I were you I would find en electric powered one which retracts when the ignition is switched off, or one made of very flexible bendy rubber.
I had fitted the latter, but wind or yobbo did manage to break it so now it has a big bulge in the middle where I've wrapped several layers of self-amalgamating rubber.
I was in Halford's today & in their clearance sale they has some flexible rubber aerials at only ?1, but alas they were bright red, so I decided not to buy as it would not look at all right on my yellow Elan.
PostPost by: john.p.clegg » Sat Jan 26, 2013 8:42 am
...and how much were they selling small tins of paint for?...
John :wink:
PostPost by: vernon.taylor » Sat Jan 26, 2013 11:32 am
Salut Steve
I bought this one for my Plus 2:
http://www.ebay.co.uk/itm/Hirschmann-20 ... 5d36d1ba4e
Quality was good and they seem a good and knowledgable outfit. I also bought a spare interior wand in case I backed into shoulder-level parking without retracting the aerial - again.
Vernon
vernon.taylor
PostPost by: SteveC » Sun Jan 27, 2013 9:57 am
Vernon
Thank you, the aerial looks a real close match. I have the original radio in the car, but it does not work.
I was thinking about not replacing it and filling in the hole?
SteveC
First Gear
First Gear
PostPost by: vernon.taylor » Sun Jan 27, 2013 5:10 pm
Find a blanking grommet the right size - no fibre glass and paint matching and you can fit an aerial if you change your mind.
Vernon
vernon.taylor
PostPost by: tonyabacus » Mon Jan 28, 2013 10:39 pm
Hi Steve
Why not get one of the radio guys to look at fixing the set, probably wouldn't cost much, these guys can even convert them to pick up fm
Tony
tonyabacus
PostPost by: billwill » Mon Jan 28, 2013 11:42 pm
vernon.taylor wrote:Find a blanking grommet the right size - no fibre glass and paint matching and you can fit an aerial if you change your mind.
Vernon
A cover for a redundant tap hole in a kitchen-sink would be a nice stainless circular disk to cover the hole.
