Lotus Elan
Early Block, crank, rods and pan
PostPost by: upnorthelan » Wed Apr 18, 2012 12:32 am
I have a Mk. 1 block "LP 3348 Lb-A," LB stamped under timing cover. Block has been boiled and checked out. At some point in it's life it was bored +.040, but the cylinders are a bit pitted and it may need sleeving. Sonic testing may show it can be furthure bored out to be cleaned up, but I believe it's at its limit being a "LB."
Set (4) 116E rods cleaned and crack tested.
4 bolt 125E crank, cracktested. Will need to be turned.
The rope seal oilpan is sort of a joke. After sandblasting there was a pencil dia. hole found near the rear. Not sure if it could be of use to someone welding up a baffled sump w/ extra volume OR used as lawn art for you diehard folks. Also have the screw-in pick up for the pan.
Looking for $550. obo for the lot and will separate things.
pixleymi *at* msu.edu
oil pan.JPG and
block 2.JPG and
block.JPG and
crank.JPG and
rods.JPG and
upnorthelan
PostPost by: upnorthelan » Tue Apr 24, 2012 12:03 pm
*Block has been sold.
rods- $125
crank- $150
pan- offers
upnorthelan
PostPost by: upnorthelan » Thu Apr 26, 2012 10:06 pm
*crank- SOLD
upnorthelan
PostPost by: upnorthelan » Mon Aug 20, 2012 5:16 pm
After a long wait to rendezvous, sale of the crank has fallen through.
Crank- still for sale
Rods- still for sale
upnorthelan
PostPost by: upnorthelan » Sat Oct 27, 2012 2:23 am
Still have 'em
upnorthelan
