Lotus Elan
lotus elan and +2 parts......the first clear out
PostPost by: theelanman » Sat Aug 20, 2011 7:43 pm
I have started to have a clear out of the garage........
this is the start of it and Im guessing I'll probably post a few more lists....
I have bags of stuff all over.....here goes
timing chain front cover
nose badge mint......genuine
nose badge chipped......genuine
gear knob....lotus emblem pale yellow (very early I believe)
windscreen wipers
cam cover std
cams std
front sidelight indicators
original seat runners
door check straps
speedo (needs a refurb as the needle has fallen off its splndle)
rev counter
ash tray
headlight rims
knackered front sidelight indicator (the metal has cracked across the top)
dipstick
starter motor with dizzy and leads
oil filler cap
timing chain/cam sprockets incl tensioner
early +2 elan S3 door handles with a key (need rechroming)
3 brand new OEM donuts (not modern repos)
5 used donuts ......
head bolts
rad top hose
rad btm hose
original dynamo (was fully working when I took it off and changed to an alternator)
fuel pump
set of handbrake pads
set of knock on rings (for the wolfrace/flat face type wheels)
handbrake cable new
std 'flywheel' fan (x2)
AP borg and beck clutch
4 dial dash early
twincam steel manifold
stainless steel exhaust system later straight though (+2s) type
early door lock (car body side....drivers side I think)
and
original chapman signature steering wheel with horn clip and original horn push
theelanman
PostPost by: Grizzly » Sat Aug 20, 2011 8:20 pm
Do you have any Pictures of the Exhaust? and how much are you looking for it? and where abouts are you?
Also do you have any Good condition courtesy lights for sale? (white oval ones)
PostPost by: theelanman » Sat Aug 20, 2011 8:47 pm
I'll get some pics of the exhaust tomorrow.....
Im in buxton, derbyshire......as for the lights......Ive got boxes and bags to go through yet so Im guessing there is a slim chance....(Ive seen the base half of one....)
theelanman
PostPost by: Grizzly » Sat Aug 20, 2011 8:49 pm
Thats handy i'm in Macclesfield.
PostPost by: martinbrowning » Sun Aug 21, 2011 9:00 am
Hello! You have PM
Martin B
martinbrowning
PostPost by: lotusbaz » Sun Aug 21, 2011 9:58 am
Hello,
I have sent a PM about the donuts
Best regards, Baz
lotusbaz
PostPost by: elansprint71 » Mon Aug 22, 2011 8:42 am
Gareth,
Missed your text- I was at VSCC Mallory Park and those aircraft engines are noisy!
Put me down for the headlamp rims and I'll send you my thoughts on the other numbers later today.
El Presidente (Mr).
PostPost by: Grizzly » Wed Aug 24, 2011 1:48 pm
If it helps you can e-mail the pics to [email protected] com
PostPost by: vernon.taylor » Wed Aug 24, 2011 3:08 pm
Salut theelanman
Could you PM me prices for:
- ash tray (black? door?)
- clutch (4-speed?)
- oil filler cap (with the rare wire attachment?)
I'd possibly be interested in the wipers if thay are in really good condition. Ditto the seat runners but postage might be a problem, though I could arrange pick-up.
Merci.
Vernon
vernon.taylor
PostPost by: lotusbaz » Wed Aug 24, 2011 5:26 pm
Hello,
Please send me a PM with the cost for two new donuts.
Best regards, Baz
lotusbaz
