Lotus Elan
Misc Lotus Elan +2 Parts - South Carolina
PostPost by: smokey73 » Tue May 19, 2009 2:42 am
I am clearing out the rest of the misc parts from my 1970 Elan +2S
Serial No 0054N. A partial list follows (as much as I can remember right now)
Located in Beaufort, South Carolina
Chapman Rear Strut (can't remember which side right now)
(have the other one but the a retaining ring landing is bad)
Twin Cam Rear Main Seal Housing 9no gasket)
Clutch master cylinder (needs rebuilt)
Front KO Hubs
4 Nader Nuts (good but could use re-chromed)
Front brake discs
Front Spindle and upright (one side)
Few other front suspension parts
Upper Front Wishbones
Lower Front Wishbones
Rear Outboard Drive Shafts (2)
Dust Shields for drive components (with clips)
Twin Cam Head Bolts (used)
Front Sway Bar
Rear Heated Windscreen (very good condition)
Petrol Tank (good condition)
Twin Cam Oil Pickup tube with screen
Twin Cam Stromberg Breather Tube
Windscreen Tudor Bottle with pump (works but seems low flow?)
Original Radio
Most dashboard switches and lamps
Many misc relays from wiring harness
Fuse boxes from wiring harness
Turn indicator column switch
Headlamp dimmer column switch
Front Springs
Rear Springs
Engine, tranny, rear end, etc are all gone as is the shell and chassis.
Contact me at [email protected] including a $ offer. I will give you a more complete description and take pictures when you contact me. There are some other parts so just let me know and I?ll let you know if I have it. I will be putting them on fleebay later but they don?t take up much room and I thought I?d check with the forum before I did that.
smokey73
First Gear
First Gear
