Lotus Elan
Bolt-On Panasports - Sold
PostPost by: 65 Lotus » Sun Apr 26, 2009 1:26 pm
Wheels Sold - 6/1/09
100_5332.JPG and
Scott In Ohio
26/3795
65 Lotus
PostPost by: Frank Howard » Sun Apr 26, 2009 3:34 pm
Scott,
Please elaborate on the "bolt head trimming" issue. Thanks.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
PostPost by: 65 Lotus » Sun Apr 26, 2009 5:31 pm
Hi Frank, and thanks for looking.
Part of the head of the bolt(s) that attaches the lower A-arms to the hub carrier sometimes interferes with the wheel just were it arcs to form the bead mount surface, and the bolt(s) have to be ground a bit to allow the wheel to clear. Sometimes it's just one. The arc of the wheel is such that there isn't quite enough clearance on some installations, although the later cars don't always have to do this at all from what I understand, perhaps others can specify.
The bolt head is ground/filed so that it takes off a bit of the corner of one flat of the head. It's hard to imagine, but easy to see once you fit them up.
I did it for both front and rear bolts, but there was still an interference issue with the A-arm on my S1. An expensive trial fit-up for me to say the least.
Scott In Ohio
26/3795
65 Lotus
PostPost by: Frank Howard » Sun Apr 26, 2009 6:19 pm
Scott,
My Elan has knock offs. I'm thinking in terms of wheels for my Europa Special. Can you tell me what the width of the wheels is and do you know if they will bolt straight on to the Europa?
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
PostPost by: 65 Lotus » Sun Apr 26, 2009 7:03 pm
Frank:
Looks like they're good for the Europa too. From Ray's website:
Panasport Alloy Wheels
13" x 5" wheels for Lotus Elan bolt-on hubs
Light-weight alloy wheels with an offset of 25mm makes them compatible with the early Elan and Europa. Weighing only @ 9.5 lb. each, these wheels are manufactured to very strict tolerances so they run very true. (25mm offset = back space @ 3.9", bolt circle dimension 4 x 3.75")
Scott In Ohio
26/3795
65 Lotus
PostPost by: Frank Howard » Sun Apr 26, 2009 9:48 pm
65 Lotus wrote:compatible with the early Elan and Europa
Scott,
I guess the key word here is "early". Mine is a Special for which Lotus furnished 5-1/2" wheels. I have the 5-1/2" factory alloys. I guess it wouldn't make sense to go to the 5" Pansports. Thanks for the information though. Best of luck with your sale.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
