Anyone who has built a car will appreciate that it's the little jobs that take up a lot of the time.
Two-part structural epoxy and 3 layers of carbon fibre should hold the blind nuts to the home made seat that is now relegated to the passenger side.
This is one of four seat bracket support bars (two each side). They need to be as low as possible as I have a lack of headroom.
- stevebroad
Thanks for the pics Steve
I see what you mean. That should work fine on the sump when I get around to it.
Dave
Dave
Dave Hughes
S2 26R
Elan DHC Sprint
S2 26R
Elan DHC Sprint
bigvalvehead - Fourth Gear
- stevebroad
- stevebroad
Not sure how I missed this thread up to now. Outstanding workmanship, I must say. When I read the first few entries I didn't imagine the level of workmanship and engineering that is evident throughout this build. I look forward to seeing more...
1963 Unicorn
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
- knockoffnut
knockoffnut wrote:Not sure how I missed this thread up to now. Outstanding workmanship, I must say. When I read the first few entries I didn't imagine the level of workmanship and engineering that is evident throughout this build. I look forward to seeing more...
Thanks, just don't look too close
- stevebroad
Tyres...bloody tyres, still trying to work out the best combination. I thought I had finally cracked it after years of searching with the Michelin TB5s.
However, the size options for 15" rims are restricted and the smallest size for the front is a little high on the aspect ratio (50) than I would like, the 225mm width option is only 5mm smaller in diameter than the 285 rears I planned to use. Pirelli do a P7 Corsa Classic in 305/35 and 235/45 with diameters within 1mm so similar difference but they come in three softness grades. What I can't find out are the Mu values so I can compare 'stickiness'.
One of my main tasks at the NEC in January is to discuss this problem with both Pirelli and Michelin to see if I can resolve my (potentially expensive) dilemma as the tyre size dictates wheel width as this has to match the footprint width in order to wring out the maximum grip.
- stevebroad
Glued in rear panels yesterday. Access to rear suspension is pretty good.
Started to think about the front firewall/bulkhead. I had planned to place it on the dash side of the crossbar, but this doesn't leave enough width for the battery so it will have to go the exhaust side. I will just have to add additional heat shielding.
- stevebroad
- stevebroad
"Anyway, I won't be sitting in it
Thanks for the laugh out loud moment this morning.
Fantastic build, great thread. More power, lighter, faster! What's not to like. It'll be what we older Yanks used to call "an E ticket ride".
Bud
1970 +2S Fed
"Every Lotus that an owner modifies makes yours worth that much more." - You're welcome!
1970 +2S Fed
Bud English - Coveted Fifth Gear
Bud English wrote:"Anyway, I won't be sitting in it"
Thanks for the laugh out loud moment this morning.![]()
My pleasure
My sister-in-law worked at the Disneyland Hotel back in the 80s so we got free tickets
On looking up Winnimucca on Google Earth I see that you live on the road to Wendover. We stayed there 2 years ago in an abortive attempt to see some action on the salt (washed out but didn't find out until we had driven 605 miles from LA) Tried again this year but at least we found out a few days before leaving LA so were able to cancel hotels. We at least managed to get to El Mirage on our last weekend so got a taster.
We will be trying again, probably in 2018. The idea will be to see some racing then tour the area. Maybe we could drop in for a coffee?
- stevebroad
Steve, the coffee is always hot and the beer cold. You're more that welcome to stop by.
...and if the salt's open I might see you there.
Bud
1970 +2S Fed
1970 +2S Fed
Bud English wrote:Steve, the coffee is always hot and the beer cold. You're more that welcome to stop by.
Thanks, added to our itinerary
- stevebroad
- stevebroad
- stevebroad
