Don't forget to inflate the tires with helium. I can identify with your efforts. Back in 1974, I drilled out the center of bolts, replaced all screws and fasteners with no serious stress with aluminum rivets, replaced many components with lighter ones with lots of holes where I could, even a motorcycle battery. Kept all shavings and removed hardware in coffee cans, and the end result was a Datsun Sunny under 1400 pounds/637 kg. This was with an all steel body, albeit many panels soaked in a phosphoric acid bath. I did have to ballast up to make minimum weight, using lead shot in small cloth bags, placed where they would balance the car to its best advantage.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Hi Steve,
I lean heavily towards originality but even I am enjoying your build thread. I am in awe of the sheer volume/fine detail of work and what you've achieved to date (having built/managed the rebuilding of a standard car from burned out which took me 7 years I think I can appreciate the progress so far).
Do you have a target date for completion?
elanfan1 - Coveted Fifth Gear
elanfan1 wrote:Hi Steve,
Been there
I have had a target date of 'next year' for the last 5 years However, I am getting close and next year should be the year. I hope to get the wiring ordered early in 2017. Once that is done the engine will be able to be started.
- stevebroad
prezoom wrote:Don't forget to inflate the tires with helium. I can identify with your efforts. Back in 1974, I drilled out the center of bolts, replaced all screws and fasteners with no serious stress with aluminum rivets, replaced many components with lighter ones with lots of holes where I could, even a motorcycle battery. Kept all shavings and removed hardware in coffee cans, and the end result was a Datsun Sunny under 1400 pounds/637 kg. This was with an all steel body, albeit many panels soaked in a phosphoric acid bath. I did have to ballast up to make minimum weight, using lead shot in small cloth bags, placed where they would balance the car to its best advantage.
Tricky to find helium at trackside. As you found out, the beauty of removing weight is that you can put it back where you want it if necessary.
My Lithium battery weighs less than 1kg.
As you, aluminium where possible, otherwise titanium which are drilled except for the suspension and drivetrain ones.
Can't acid dip fibreglass, but lots of holes and sanding of inside surfaces where accessible.
- stevebroad
RE: Nuts and bolts - saving weight
Depending on the fastening torque values, change to aluminum, then titanium.
Get nuts 1/8 to 1/16 smaller, tap them out to size.
Shorten nuts to 3 or so threads.
Measure the length bolts need to be to barely extend from the nut. Buy bolts that length.
Depending on the fastening torque, center drill the bolts.
Shorten the head depth. Center drill the head.
Use only hex headed nuts and bolts. Sockets are more secure when you thin the heads and nuts. Get ratchet drivers/torque wrenches to tighten/loosen.
Any more ideas?
David
1968 36/7988
Any more ideas?
David
1968 36/7988
msd1107 - Fourth Gear
Depending on the fastening torque values, change to aluminum, then titanium. - DON'T FORGET NYLON. DONE
Get nuts 1/8 to 1/16 smaller, tap them out to size. - HADN'T THOUGHT OF THIS ONE
Shorten nuts to 3 or so threads. - CAREFUL AS THIS CAN REDUCE TORQUE CAPABILITIES OF NUT
Measure the length bolts need to be to barely extend from the nut. Buy bolts that length. 1.5 THREADS IS RECOMMENDED. DONE
Depending on the fastening torque, center drill the bolts. - DONE
Shorten the head depth. Center drill the head. SEE ABOVE
Use only hex headed nuts and bolts. Sockets are more secure when you thin the heads and nuts. Get ratchet drivers/torque wrenches to tighten/loosen. AGREED.
- stevebroad
12 points and jet nuts.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
26-4889
50-0315N
1964 Sabra GT
- prezoom
prezoom wrote:12 points and jet nuts.
That's the way to go. Not cheap but you can't take it with you, as far as I know.
- stevebroad
stevebroad wrote: but you can't take it with you, as far as I know.
Have you tried travellers cheques......failing that dont go
types26/36 wrote:stevebroad wrote: but you can't take it with you, as far as I know.
Looked into those, but I kept hitting a dead end.
- stevebroad
Finished seat brackets for the new seat today. Bought a pair of OMP 6mm thick brackets as a starting point. Bloody heavy but I thought that I could remove at least a Kg from them. They needed to be trimmed to clear the seat at both ends and could do with a few more holes
After a bit of experimenting and trial fitting I settled on what I needed to remove.
You may be thinking, why have I painted them? Paint has a weight, but it also disguises the many imperfections and shoddy finish They will be mostly hidden so I decided not to spend too much time on them. A total of 740gms removed. Not the 1Kg I was looking for but decided that stiffness was more important than lightness in this situation.
These brackets will sit on steel supports running from the sill roll bar to the tunnel. If you are wondering why the square tubes aren't centred over the lowered section of the floor, this is because this was originally designed to suit the seat I was making. The Reverie seat has a different fixing configuration, but it still fits in the hole
- stevebroad
- stevebroad
Spot on with paint. I anodized the aluminum panels and other bits. Door panels were carbon fiber, which I mixed blue dye into the epoxy. When the sun hit it, it looked like gun bluing. Did the same with the front air dam.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
26-4889
50-0315N
1964 Sabra GT
- prezoom
