Alex Black Elan Window Clamps
Posted: Fri May 21, 2021 6:09 pm
Hi there
Looking for some help from someone who is using or about to use Alex Black's Cable / Window Clamps
on the Lotus Elan.
I got an early revision from Alex many many years ago but having problems with them not gripping the
Cables tight enough when I tried them in past week with motor attached for trial run. (Alex is not well at the moment)
I have confirmed that they are not the same design as the ones being used by people the past several years
and think this is reason they are not functioning properly.
So what I am looking for is a sketch of the Clamps with the dimensions especially the size / shape of the hole
where the two Cables pass through and if there is 1 or 2 4mm Grub Screws per Clamp. I suppose basically a sketch good enough for me to make some new ones.
Many thanks.
Dino246GTS#
on the Lotus Elan.
Many thanks.
Dino246GTS#
