Plus 2 column stalk upgrade
has anyone fitted an upgrade to put wiper controls on steering column stalks? Spyder have a mod to use Mini stalks but it's very expensive.
- mikealdren
That kind of stuff can run from very cheap to very pricey... From some junkyard bit ziptied in place to an expensive switch with custom brackets and a fancy replacement cowl piece . In support of our suppliers you should save up and buy from them. The triumph column has a unique way of attaching the switches and modifications would have to be made to the column itself to make that work. Only easy thing I could see is looking at the possibility of fitting up a triumph headlight switch to the wiper system. I don't know if the way the electricity flows in the switch can be made to work.
- Billmack
Interesting - I've been thinking about a stalk mounted single wipe arm off the steering column and been considering it against an electronic intermittent wipe unit.
Still undecided at the mo.
Gavin
Gavin
gav - Fourth Gear
I am currently making a wiper/headlight double stalk from an MGRV8 (that I think has come from one of the Rover parts bins) - it is a good fit, but does, like any such mod, require removing the upper part of the column and cutting the dashboard.
I also have a Mini stalk that might be better if I prefer a smaller diameter wheel.
Hal Adams
Evora S
Elan +2
Evora S
Elan +2
HCA - Coveted Fifth Gear
