Lotus Elan
Coil Pack LocatIon
PostPost by: c.garde » Tue Jul 04, 2023 9:41 pm
Big thanks to damianB.
I see from your uploads that your Nodiz is of the latest version.
Maybe these are less prone to panic reactions than the earlier nodiz pro 2.?
Anyway I was advised by the Nodiz people the recommended 50 cm. - and that 30 cm probably would work.
I am inclined to protect the the 2 sensor leads in a grounded sheet for added isolation to be on the safe side.
However I am stuck for now being rather confused by the many suggestions for the advance curve.
- add to this the alfa N set up. :roll:
Many years ago Kenn Snailham of QED recommended that the best update for a TC would be a set up as pr. this discussion. And that included injection :!:
Must get my act together.
Best regards
C.Garde.
c.garde
PostPost by: berni29 » Fri Feb 09, 2024 7:49 pm
Hi Damian
Thank you for providing your the write up for the coil pack positioning. I will certainly be doing this.
Many thanks
Berni
berni29
Previous
