Adjustable rear wishbone
Tue Sep 01, 2020 1:57 am
by Sking06
Has anyone install the Kelvedon adjustable rear wishbone on their Elan? If so, any comments?
Thanks in advance
Skip King
‘69 Elan S4 SE
‘61 Seven S2 America
Re: Adjustable rear wishbone
Tue Sep 01, 2020 8:19 am
by miked
Skip,
If you are talking about the ones with the turnbuckle in the rear leg of the A frame,
no, but have fitted that design on at least 6 cars. Works very well. Slight turn corrects toe out.
Don't believe all the business about tension and stress. If you put the saw through the rear leg they generally pull apart leaving a gap. So under tension.
The amount of adjustemt to effect correction is so slight. Part of a turn. Plus you only do it once. Also you get to keep rubber or poly bushes.
There is an old thread on here were I showed how to make up your own (with photos) using an off the shelf turnbuckle. On round section Lotus A frames.
Cheers Mike D
Tue Sep 01, 2020 10:20 am
by gino1
Skip,
Totally agree with Mike's comments.
I made my own and the result is very good as a slight adjustment will correct any misalignment and or give you the desired set up.
Gino
Tue Sep 01, 2020 10:42 am
by greg40green
PM sent .
Thanks , Greg.
Sking06 wrote:Has anyone install the Kelvedon adjustable rear wishbone on their Elan? If so, any comments?
Thanks in advance
Skip King
‘69 Elan S4 SE
Tue Sep 01, 2020 4:58 pm
by Sking06
Thanks for the positive input. I like the idea of keeping the original bushings...
Skip King
‘69 Elan S4 SE
Tue Sep 01, 2020 7:26 pm
by Bits
Like these?
