HUCO located in boot 133000
iirc I fitted a Huco 133010 in the trunk of my street Fed S4, which I believed at the time good for 2.5psi hence adding lightness of no regulator - I checked it statically with a pressure gauge mounted on top of a modified Weber banjo bolt, and the pressure was actually a bit less but did not go below 1psi at full revs (6800 rpm for the test), so I don't think this is what would be limiting the engine.
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Gentlemen,
Thanks for your help.
Richard Hawkins
Richard Hawkins
- RichardHawkins
We have used both the Huco and Facet pumps over the years on our rally and sprint cars. Have a Huco currently fitted to our sprint car in the engine bay. You will find the Huco runs a lot quieter than any of the Facet pumps if you are running a road car. Cheers.
- jasper2347
