Spyder Power Steering
Fri Apr 29, 2016 1:01 pm
by Robzildjian
Hi all,
Has anyone tried the power steering option for the plus 2 Zetec from Spydercars? Opinions appreciated.
Rob
Re: Spyder Power Steering
Fri Apr 29, 2016 2:23 pm
by Sea Ranch
Is that a delayed April Fools' joke?
Fri Apr 29, 2016 3:38 pm
by msd1107
Why would a person need power steering in a Lotus????
Fri Apr 29, 2016 6:11 pm
by Spyder fan
Rob,
I hope to have a go next week and will report back. The system utilises an electric power steering unit from a Vauxhall Corsa or similar. It fits under the dashboard inside the car.
Steering effort at parking speeds is quite heavy on a Spyder +2 Zetec conversion, wider stickier tyres don't help matters. Its not an upgrade I'm planning myself, but it doesn't hurt to try it out.
I would rather spend the money on the new Air Con upgrade
Fri Apr 29, 2016 8:13 pm
by holywood3645
I think these are the same items that are sold for the MK1 and Mk2 ford escort. May be worthwhile to check those sites out.
James
Fri Apr 29, 2016 8:41 pm
by Sea Ranch
Ah . . . "new air con upgrade" . . . now you've got my attention
Sat Apr 30, 2016 1:12 am
by gus
I'm a fan of Spyder, but if they need power steering in a plus two, there is something wrong. I've run 205's for 25 years and never wanted it. Shimmed in a degree of castor and it made it just a touch heavier at a standstill, but to the extent that my finger gets dented spinning with the wheel spoke
Sat Apr 30, 2016 8:27 am
by SimonH
I expect it's more a case of what customers have asked for than needs it.
Just because an enthusiast doesn't want it doesn't mean it shouldn't be offered.
Sat Apr 30, 2016 8:32 am
by Robzildjian
Thanks Alan and James - very helpful.
Rob
Sat Apr 30, 2016 10:41 am
by Robzildjian
Incidentally, I don't think I want it either but I was just interested from a technical perspective in how good it is.
Sat Apr 30, 2016 5:29 pm
by elan66
man up
Sat Apr 30, 2016 9:26 pm
by gus
I have driven small cars[an 85 CRX comes to mind], that needed power steering. Many modern cars though small, weigh quite a bit, and with front wheel drive putting all that weight up front, and torque steer etc, power steering is a welcome addition in many cars. My former M100 had power steering and I was not offended, but people have asked my if the Plus Two had power steering when watching me park, so it is bewilderment at the need or desire more than dogmatic fist shaking that makes me comment.
I have quite literally driven my Plus Two with two fractured elbows with no ill effect, so that is my perspective...........
Sun May 01, 2016 4:28 pm
by Spyder fan
The steering geometry is different on a Spyder Zetec, it doesn't use the Triumph steering rack and the hubs and uprights are from a Ford Sierra, steering effort is increased over a standard +2. I don't have a problem with it, but those used to moderns or those encouraging partners to drive may have.
Mon May 02, 2016 12:14 pm
by gus
Wonder if they have reduced the turns lock to lock, lots of castor, or some other thing that increases effort
Thu May 19, 2016 12:35 am
by Foxie
Spyder fan wrote:The steering geometry is different on a Spyder Zetec, it doesn't use the Triumph steering rack and the hubs and uprights are from a Ford Sierra, steering effort is increased over a standard +2. I don't have a problem with it, but those used to moderns or those encouraging partners to drive may have.
I have converted my Plus 2 to the Sierra hubs and vented discs. The wishbone are identical geometry to the originals. The hubs are Sierra, but the uprights themselves are exactly similar to original Lotus, except for the bottom ball joints. So it would seem the steering geometry is unchanged. I don't know the gearing of the Zetec rack, so steering effort might be different.
