Re: Electric headlamp conversion.
Posted: Sun Apr 19, 2015 3:05 pm
Probably not as good as Doulag's bracket but might be interesting to some and can be made with basic tools and skills...
I made a simple U shape bracket for mine. Each side is 145mm x 90mm, the base is 65mm x 90mm. I used sheet Ali and did a 15mm folded lip for extra strength.
The motor is bolted to the double thickness edge. The 1/4 inch bolts run though 1/4 x 1" spacers to allow for extra depth of the motor versus the mounting lugs.
Is bolted to the car with 3/8 bolts in the top right and central original mounting holes, bolted with large washers.
