March '68 +2, 1 prev owner, 138Bhp - UK
Posted: Sun Aug 21, 2022 4:24 pm
Selling my March '68 +2 which i rebuilt in 2019.
1 previous owner !!
The car had a full rebuild with an extensive list of 'enhancements'
I rebuilt the engine in 2019 when it was +40' with QED 360 cams and a ported / polished head (reground crank, balanced, shortened jackshaft, new guides and seats etc), in 2020 I opted to go for QED 420 cams with adjustable cam pulleys and take the opportunity to have the block sleeved back to standard bore and installed Omega pistons, and a new Helix clutch kit, the car was still running on the rebuilt DCOE Webers at this point and after the rebuild I had it ran in and jetted at Northampton Motorsports. Ever one to tinker and not being especially happy with the Webers, I fitted Fuel Injection in 2021 with an Omex ECU and crank triggered injection. again, it went to Northampton Motorsports to be calibrated and finished up with a very useable, drivable and economical 138Bhp.
Lotus Galvanised Chassis (fitted in 1994 I'm told, but the car never returned to the road until I got hold of it)
Stainless inner sills
Sue Miller CV driveshafts
Spyder front and rear tubular wishbones
New wheel, diff, prop and gearbox bearings and seals
Gearbox stripped and rebuilt with new selector forks
New head lining, + carpets, front seats retrimmed and boot re-boarded and carpeted - sound deadening throughout
Modernised electrics with relays and a comprehensive fusebox
Dash stripped and re-laquered (veneer was good)
Re-cored Radiator fitted with electric fan
Burton modular waterpump
Baffled sump
Twin circuit AP brake master
New clutch master and slave
All calipers rebuilt with stainless pistons
a good friend is an electroplater, so everything reused has been replated - calipers, various nuts + bolts etc
TTR front and rear suspension
Mx5 fuel filler and re/routed breather mods
MX5 headlight motor conversion
Rebuilt pedal box with removable access panel, new silver steel removable axle shaft, pedals bored to take acetal lined bronze bushes
Rebuilt steering rack with solid rack mounts
Stainless door hinges with brass bushes
stainless exhaust inc manifold from Sue Miller
Lots of other things which I'll probably add when i remember!
I'd like to think I've done everything possible to make this car as reliable and liveable as possible. It has no hidden problems nor anything waiting under the woodwork to come out, everything had been addressed and I am sure it will give years of trouble free motoring. I have a comprehensive receipt file from the rebuild and ongoing improvements
Sitting on 89k miles
I'm asking for £25500
Located in Northampton
07923993455
Tom
1 previous owner !!
Baffled sump
07923993455
Tom
