Elan +2
1972 lotus Elan 2+2 with all original matching numbers
Date of Registration 23rd September 1972, the car has a current V5 and is on SORN
Just over 37 years dry storage with 68000 recorded miles
Engine dismantled a rebuild was started but never completed, BIG VALVE cylinder head, rebuilt by Lotus Engineer some new parts along with existing see full list. The only item that appears to be missing is the distributor
Gearbox also rebuilt with bearings at the same time.
Front suspension rebuilt with the original parts retained
Body dirty but sound with fatigue cracks at pop up headlights, now finished in dark blue was formally yellow, the original black interior remains fitted pop up sunroof the whole car needs refurbishing and refinishing , rear bumper damaged.
This is a significant opportunity to buy and put an original Elan +2 back on the road,
Full Parts List
Engine
Cylinder Block (original)
Cylinder Head (reworked and ready to fit)
1 pair of 40 DHLA original carburettors
Rocker Cover (Big Valve)
Crankshaft
Conrods complete with pistons x 4
Radiator with electric fan
Timing chain (Used) x 1
Timing Case Cover Outer
Timer Case Cover Inner
Oil Sump x 1
Oil Pump x 1
Dipstick x 1
Main Bearing Caps complete with bolts x 5
Rear Crankshaft Seal and housing x 1
Cylinder Head bolts x 10
Oil Filter x 1
Pick up strainer x 1
Water Pump impellor (damaged) complete with pulley
Camshaft oil sprockets complete with oil thrower x 3
Front Pulley x 1
Main Bearings (Used) x 6
Thrust Washers (Used) x 2
Fuel Pump complete with spacer
Starter motor solenoid
Ignition coil
Oil Pressure relief valve
Rear Gear Box Cross Member
Front Suspension Bushes (NEW)
Flywheel Front Cover Plate
Spark Right Ignition
Radiator complete with electric fan
Alternator complete with bracket x 1
Flywheel x 1
Clutch assembly x 1
Starter Motor x 1
Brake Servo x 1
Headlight vacuum tank (rotten) x 1
Headlight vacuum tank (New) x 1
Exhaust Manifold (Damaged) x 1
Headlamp Washer pump x 1
Clutch Hydraulic Hose x 1
Steering Rack Gaitors x 2
Engine Mounting x 1
Assorted displaced front suspension part with assorted bolts
Front Anti Roll Bar x 1
Original workshop manual
Air Filter x 1
Gearbox 105E 7505B
New Engine Parts still boxed
Timing Chain x 1
Big end bearings (complete set)
Main Bearings (complete set)
Thrust washers (complete set)
Master cylinder repair kit (New) x 2
Slave cylinder repair kit (New)
£9,000
Full Parts List
Engine
Crankshaft
Oil Sump x 1
Oil Pump x 1
Dipstick x 1
Oil Filter x 1
Front Pulley x 1
Ignition coil
Flywheel x 1
Clutch assembly x 1
Starter Motor x 1
Brake Servo x 1
Engine Mounting x 1
Air Filter x 1
Gearbox 105E 7505B
Timing Chain x 1
£9,000
- CarolG
hello Carol,
suis intéressé pour ELAN S2 ;
-arbres entrainement en conversion performance unlimited
-démarreur a couple élevé
-combiné amortisseurs avant Koni si =S2 ?
Demande de prix et pour expédition en France
- geni
[quote="CarolG"]
If anyone is interested, I have a 1972 distributer available for a small donation to The Lifeboats...
- HCA
Gérard (Geni)
The vendor wishes to sell the above as package I believe..."This is a significant opportunity to buy and put an original Elan +2 back on the road,"
Le vendeur souhaite céder la voiture avec le tas de pièces...Il n'y a pas de vente par pièce. Sauf erreur de ma part!
Andrew
Andrew
- Frogelan
geni wrote:hello Carol,
Hi Geni
Many thanks for your message, the car will be sold with the complete parts list,
These parts belong with this car
Carol
- CarolG
Frogelan wrote:Gérard (Geni)
Andrew
Hi Andrew
Yes, you are correct, I am hoping to sell the complete package and not break it up
Thank you
Carol
- CarolG
HCA wrote:CarolG wrote:t. The only item that appears to be missing is the distributor
Thank you,
I will keep this in mind
Carol
- CarolG
Where a bout's are you Carol?
- Bits
Bits wrote:Where a bout's are you Carol?
Bedale in North Yorkshire
- CarolG
