1965 S2 Racing Elan
I have come to the conclusion that I will not be getting back into racing--consequently my Elan is for sale. This car won the Pacific Northwest Championship in 1967, 68 and 69. All matching numbers (!).
It was modified to almost 26R specs in period: adjustable rear suspension, steel crank (four bolt), BRM cams and modified head. Twin master cylinders (removed). Close ratio gearbox. Sliding joint rear driveshafts with billet output shafts and limited slip diff.
Hard top, original soft top like new, tonneau cover. Set of four 6" Cosmic wheels in addition to strengthened originals with hub caps. Low miles, four owners from new. Immaculate condition. Fully documented history. In full road trim.
Do I hear $35,000? davidandandrea at telus dot net
Edit: presently replacing water pump...
'65 S2 4844
- Davidb
Current: 1965 S1.5 26/4004, 1966 S3 FHC 36/5192, 1958 Fiat Abarth 750GT Zagato, 1967 Brabham BT21B, 1988 Arrows A10B-04, 1991 Brun C91-001.
Past: 1971 Elan S4/SE DHC, 1972 Europa Special, 1980 Esprit Turbo, 1988 March 881-05, 1990 Leyton House CG90105
CG901 - Second Gear
