Engine hitting bonnet S4
PostPost by: mazlot » Sun Dec 01, 2024 6:18 am
Would some-one be able to measure the height from the chassis cross tube (top) to the underside of the crankshaft pulley.
My measurement is 45mm approximately.
Have new engine mounts, fitted correctly.
Body mounts all bolt up correctly, so spacers not required to lift body.
Have the correct gearbox mounts spacers, adding more height at the gearbox mount does not alter the engine hitting by any great amount.
Other thoughts or opinions greatly appreciated.
I assume there are only one type of mounts, as they appear to sit the engine rather high in the chassis.
mazlot
Users browsing this forum: jdouglas300, Phil.C60 and 29 guests
