Lotus Elan
Engine mounted cooling fan options
PostPost by: 2cams70 » Thu Jul 11, 2024 8:16 am
Maybe but the Ford fan bolt mounting PCD is unlikely to be the same as a mini. Could be wrong though. Perhaps that’s why the pictured Lotus one has two sets of holes instead of one like the pictured Mini Fan.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: MartijnElanS4 » Thu Jul 11, 2024 8:34 am
Very interesting;
Bear in mind I am not the mechanic but how about:
Maybe I will make a quick set up and turn the Fan on a drill or so taking the rotation direction of the engine into account and blow smoke. Then I can see what actually happens with the air flow.
MartijnElanS4
First Gear
First Gear
PostPost by: Andy8421 » Thu Jul 11, 2024 3:59 pm
MartijnElanS4 wrote:Maybe I will make a quick set up and turn the Fan on a drill or so taking the rotation direction of the engine into account and blow smoke. Then I can see what actually happens with the air flow.
Martijn,
The Elan engine rotates clockwise when viewed from the front. If you imagine your fan on the page rotating clockwise, it will blow air into your face. This is the wrong direction for an Elan.
Unfortunately, flipping the fan over does no good. At first sight that should solve the problem, but a bit of thought shows that the fan still blows the same way.
32 Standard 12
Various modern stuff
PostPost by: alan.barker » Thu Jul 11, 2024 4:49 pm
Yes Martjn,
Your Fan blows the wrong direction.
That one is for an Austin Mini which blows air through Rad to exit under Wing.
PostPost by: MartijnElanS4 » Thu Jul 11, 2024 6:26 pm
Thanks a lot all for the feedback.
Never thought of that being possible having been on there so long.
Now let’s look for a correct one.
MartijnElanS4
First Gear
First Gear
PostPost by: vtauto » Thu Jul 11, 2024 9:50 pm
You wouldn't believe how refreshing I find this discussion to be. The buddy that I own the car with thinks I'm an idiot for not finding the right fan in 10 minutes.
And I get the technical benefits of a clutched or electric fan. In our defense, I can only say that if max power was high on our list of priorities, this probably wouldn't have been the car we chose. The E-Type we had prior to the Elan had a slightly twisted flat 1" bar for a fan that made a lawnmower blade look like a technical tour-de-force, but it was original and still worked fine. Same approach here.
vtauto
New-tral
PostPost by: alan.barker » Fri Jul 12, 2024 4:20 am
True vtauto,
But 5 hp counts when you are only pulling 700 kgs.
PostPost by: elanman999 » Sat Jul 13, 2024 10:43 am
Here is the one that was fitted to my early +2 when I bought it in 1977. It's been sitting in a box ever since as when I rebuilt the car I fiited an electric fan.
John.
P1060141rs.jpg and
elanman999
PostPost by: alan.barker » Sat Jul 13, 2024 8:25 pm
There was a metal fan like that on my first 1968 +2. When the Water Pump Bearing gave up the metal Fan "Tripaned" the Rad very nasty.
PostPost by: vtauto » Sun Jul 14, 2024 3:36 pm
The two bladed metal fan that came on many of the cars seems like a bad idea for a few reasons. Someone suggested this 11 bladed fan which at least looks like the plastic option in the parts manual. I've got a call into the supplier to get more info on it.
IMG_6951.JPG and
vtauto
New-tral
PostPost by: gjz30075 » Sun Jul 14, 2024 7:56 pm
^^^ Who's the seller?
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: vtauto » Sun Jul 14, 2024 10:50 pm
Lotus-mistry.com
vtauto
New-tral
PostPost by: MartijnElanS4 » Mon Jul 15, 2024 6:12 am
Hi everyone,
You were right: we did the test yesterday with a bit of smoke for visuals and drama haha by blowing some smoke. The fan blows instead of sucks air.
Thanks a lot; off to get a new one.
Best Regards,
Martijn
MartijnElanS4
First Gear
First Gear
PostPost by: 2cams70 » Mon Jul 15, 2024 6:15 am
vtauto wrote:The two bladed metal fan that came on many of the cars seems like a bad idea for a few reasons. Someone suggested this 11 bladed fan which at least looks like the plastic option in the parts manual. I've got a call into the supplier to get more info on it.
That's the Ford Escort Twin Cam fan. Was also used on standard Mk2 Cortinas and Capri's. It may not fit a Lotus due to what appears to be less clearance between fan and radiator compared to the Fords. The Ford two bladed metal fan used on Loti is a lot thinner
PostPost by: elanman999 » Mon Jul 15, 2024 8:17 am
If you look at the +2 parts list you'll find that the electric fan was used after the change over to the narrow radiator, that was around chassis no 928, so mid 1968ish ?
John.
elanman999
PreviousNext
Users browsing this forum: ericbushby and 21 guests
