gearbox screws
Can anyone tell me the size of the 4 bolts that hold the gearbox onto the bellhousing ?
Gino
Gino
1964 Elan S2 Roadster
1965 Elan S2 Roadster
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1982 Lotus Esprit S3
1961 Ford Anglia
2000 Lotus Elise Motorsport-56
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1 - Third Gear
Off the top of my head, 1" seems to short to me, but could be wrong. By the time you have got a washer and a spring washer on there, there wont be much thread left. More like 1 1/2".
The picture got me all confused. Thinking of the bellhousing to block.
Leslie
Leslie
- 512BB
gino1 wrote:Can anyone tell me the size of the 4 bolts that hold the gearbox onto the bellhousing ?
Gino
As Brian says, they are 1" long - that is the "under head" measurement.
These were the original length bolts used in the wide-ratio gearboxes with a large size 4th gear on the cluster - if you used anything longer than that the one bolt that goes through to inside of the gearcasing would hit the cluster gear as the larger gear is visible through the hole.
The threads don't need to be any longer as there' only so much female thread available.
All gearboxes thereafter whether wide/semi/close ratio used the same 1" long bolts.
promotor - Fourth Gear
