Keeping It Original
Hi Tim,
Thanks, I have never noticed that arrangement before and I find it odd to trap a high voltage cable between two earthed metal parts. Having worked on high voltage industrial equipment all my working time that looks a likely failure point. I would not do it that way.
Eric in Burnley
1967 S3SE
Eric in Burnley
1967 S3SE
- ericbushby
ericbushby wrote:Hi Tim,
Eric in Burnley
1967 S3SE
I'm with you Eric.... asking for trouble...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
I understood that the ignition leads were originally routed round the back of the head and through the hole in the head casting. Then a metal plate was fixed to the cam cover, over the plugs to reduce radio interference.
It may be more original than you think.
What a find, well done.
Eric in Burnley
1967 S3SE DHC
As Eric says, your ignition leads are in the ORIGINAL position for cars fitted with the radio suppression kit.
i.e round the back and into the spark plug crevice through the rectangular hole at the back of the cylinder head.
But if so, you are missing the aluminium plate which covered the spark plug crevice. It was held on by 4 of the cam cover bolts. My car had one originally, but the plate was never replaced after the first renovation in 1983 and I didn't chase it up as it wasn't very effective anyway.
Loving this topic and I wouldn't expect anything less from you Tim, or indeed, for that car!
Are you going to be going through the car front to back overhauling the brakes, suspension and steering?
How is the car for oil leaks and the dreaded water drip from the water pump?
My S4 had been off the road and not run at all since 1985, was it was no surprise that everything needed doing on that. But I also found that the S3 needed almost as much work, and whilst it hadn't been on the road for quite a few years, most things had sprung a leak.
The surprising thing with the S3 was that the Rotoflex coupling still looked to be in perfect condition with no cracks or splits. I put those on in 1979 !
One thing that I would urge is to overhaul the brake system completely if it hasn't been done in the past few years. I used to overhaul the callipers myself, but with them being over half a century old, I now entrust such work to the pros. I used Bigg Red in Worcester for my S3 Calipers, and they did a fantastic job on the 4 calipers for £350 including postage!
One other thing that could make a big difference is to get the wheels checked out for being true, blasted and re-painted. No point in going for super new tyres unless they are right!
If you want to spend £350 that's fine, but restoring the callipers is an easy job to do yourself really.
- AshleyPark
Great to see the right car with the right person. Who has the right mindset and elan knowledge to keep an original car in it's factory condition.
It's important that these cars exist and are used for the pleasure they give.
- Bits
billwill wrote:ericbushby wrote:Hi Tim,
Eric in Burnley
1967 S3SE DHC
With the full radio suppression kit fitted you couldn't route the HT leads around the back of the engine. As well as the ally plate covering the valley between the cams there's also a plate covering the back of the engine attached where the gearbox bell housing joins the block. There's no gap for the leads to go through there (or if there is there's more risk of the leads rubbing/shorting) so they would have to go between the carbs and over the top of the inlet cam cover.
Craig Elliott - Third Gear
Craig Elliott wrote:With the full radio suppression kit fitted you couldn't route the HT leads around the back of the engine. As well as the ally plate covering the valley between the cams there's also a plate covering the back of the engine attached where the gearbox bell housing joins the block. There's no gap for the leads to go through there (or if there is there's more risk of the leads rubbing/shorting) so they would have to go between the carbs and over the top of the inlet cam cover.
Actually yes there is plenty of room, these 2 photo's are of that area of my car with the full suppression kit fitted:
The spark plug wires pass below the cylinder head corner where it would be in close proximity to the suppression plate.
Phil Harrison
Tim,
Your car looks lovely. I still have the original radiator and fan for my car in the garage but given the traffic these days I added an earlier style wide radiator, a slightly more modern Kenlow fan, a manual switch for the fan and hazard lights. I still have donuts as they make driving the car 'interesting'. I have Lucas electronic ignition which was recommended to me by Peter Day in the 1980s as getting to the points is a bit of a bugger. All in all a few changes which make the car more able to cope with modern driving but nothing which can not be reversed.
Have fun with your Sprint
Carl
Carl
pereirac - Coveted Fifth Gear
deleted, irrelevant.
Looks a real beauty Tim! Sounds too like you're going to have a lot of fun with it!
1969/70 Elan Plus 2 (not S) 50/2036
The Veg - Coveted Fifth Gear
Having got the car home and then spent some time giving it a good look over, I began to draw up a list of work to be done. I had already booked the car in with my mechanic, let’s call him Colin, so that he could change all the fluids and give it a good look over, up on the ramp and report his findings. I ought to mention that Colin is what us boomer generation would call a good old fashioned motor mechanic, even though he is a little younger than me. He is a Jaguar enthusiast but spends a good deal of his time spannering for a serial Lotus collector, who has an original Six, a race winning XI as well as a Sprint in his 30 car garage. So I have no qualms about handing my car over to him.
I also wanted to put a few more miles onto the car, especially on country roads, to get to know it even better. Since my list included a few parts, I thought I’d drive over into the next county and visit the ever-helpful Susan Miller. It was a warm spring day, so the roof came down and I set off cross country, to enjoy some good Elan roads. Which I did!
As usual, Susan was most welcoming and allowed me to wonder around her Aladdin’s Cave of Elan parts, ephemera and photos of Mick. We had a good long chat and she gave the car a good long look over, noting the originality of many parts on it. With a bag full of service items I said my goodbyes to her and spent a couple of hours in the early evening wending my way home via a different cross country route, largely devoid of traffic. The air was heavy with the scent of early summer, the crops coming through, the verge-side cow parsley, occasional wafts of newly mown grass as I passed through villages. The sun was still warm and I was able to enjoy myself at the wheel of the Elan even more!
The handling was as good as it should be, the ride as superb for a 60s sports car as Chapman and Hickman intended, the performance delightful. I did not drive flat out as I was acutely aware that the tyres need replacing. They have more than enough tread but I could not trust twenty six year old rubber to do what it was intended for back in the 90s!
Over the next couple of days I was able to do some odd jobs, such as ordering a spare set of keys from Morelands, some Millers Classic Sport 20w50 from Oppie Oils, a can of Lotus Yellow from the Touch-Up Paint Factory and a Classic Certificate of Provenance from Andy Graham at Hethel.
By the time Colin arrived with his low loader to take the Sprint off to his workshops, I had driven just over 650 miles. I remained very pleased with my purchase and grateful that my gut reaction to the car had been correct. However, now for an expert mechanic to give it the once over. What would he find?
This was the list of work I handed to Colin:
The steering wheel is not centralised. It can be rectified of course, but first we should investigate the tracking of the car once the new tyres have been fitted.
The indicators work, but tick erratically.
Hot starting is an issue. The Dellorto carbs appear to be well set up and tend to hold their tune well. It may just be that I have to get used to it.
The speedometer has a delay during acceleration. Its as if the needle is held back momentarily before it pings round to about the true speed. Watching brief.
The tachometer bounces sometimes. This is pretty normal for Elans and there may be no fix.
The clutch needs investigating. Reverse is hard to engage and disengage. Clutch makes a clicking noise when engaging.
Change all fluids.
Check cylinder compression. Note any engine issues.
Change air filter element.
Check distributor operation and for wear.
Check water pump operation and for any weeping on the front chest. Check all hoses. Fit new thermostat and fan belt.
Check brake pads and operation.
Check all suspension and steering bushes. Check over suspension wishbones for straightness. Check over shock absorbers and springs. Check driveshaft doughnuts.
Check over entire chassis, note any areas of concern to discuss. Check for straightness as far as is possible.
Check all lights are operational.
Change all fluids.
- Attachments
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
