Can you identify this?
PostPosted: Tue Jun 16, 2020 4:24 pm
by Pete M
I suspect this is a fuel pressure regulator, but I've never seen one like it. If it is, is it set right?
Re: Can you identify this?
PostPosted: Tue Jun 16, 2020 4:33 pm
by Grizzly
You would be correct....... usually paired with an aftermarket electric fuel pump (https://www.advancedautomotives.co.uk/s ... 2304-p.asp)
I have a slightly different version regulator but i run mine on 2psi!! (yours looks like it's set to 4.5psi), that said i have Webers so couldn't say for sure if they prefer a different pressure.
PostPosted: Tue Jun 16, 2020 5:01 pm
by Pete M
Mine has ZS CD-175's. I wonder what pressure is recommended?
PostPosted: Tue Jun 16, 2020 5:53 pm
by david.g.chapman
I have the same regulator feeding my stromberg carbs, purchased from Burton Power over 15 years ago. I usually set the pressure for 2psi.
Dave Chapman.
PostPosted: Tue Jun 16, 2020 6:03 pm
by Concrete-crusher
Looks a bit like mine and with weber I have it at 1, seems to work just fine
