Left hand drive to right hand drive
Thu Dec 19, 2019 3:41 pm
by mrfettler
Hi does anyone know if its possible to change a elan s4 from LHD to RHD and if so apart from a steering rack and dash are any more parts needed ?
Milk
Re: Left hand drive to right hand drive
Thu Dec 19, 2019 3:55 pm
by elated
Probably headlights & mph speedometer, maybe a RH wheelhammer
Thu Dec 19, 2019 4:10 pm
by nmauduit
pedal assembly
Thu Dec 19, 2019 6:18 pm
by lotusfan
Dashboard wiring harness and if it came from US rear lights will need changing.
Thu Dec 19, 2019 6:26 pm
lotusfan wrote:Dashboard wiring harness and if it came from US rear lights will need changing.
I don't think the wiring harnesses are handed, they built slack in there to fit either side...
Thu Dec 19, 2019 8:13 pm
New brake lines and clutch line needed, unless you can modify your lhd ones. Throttle cable different
length, too.
Fri Dec 20, 2019 7:46 am
by oldelanman
Handbrake pull handle.
Fri Dec 20, 2019 8:59 am
I think it's just Triumph Spitfire Steering Rack, new Dashboard, shorten Throttle Cable, maybe adjust Pedals.
Brake Pipes maybe you will just need to shorten the one from Brake Master Cylinder to multiway block.
Clutch line made longer like original or fit flexible Aero equipe type hose.
Wiring Harness is OK on baby Elan, it only needs changing of some wire lengths on a +2 Elan.
If you need parts try contact with Club Lotus France as many have done the opposite to you. They may have the parts you need kicking around. Serge Audiger the secretary of the Club speaks English no problem
bon chance
Fri Dec 20, 2019 9:04 am
by Mazzini
LHD and RHD pedal boxes are very different. New RHD boxes are available for a reasonable price.
Fri Dec 20, 2019 9:52 am
Thanks i didn't know on the baby Elan they are different.
So i suggest you contact Club Lotus France. I know several baby and +2 Elans have been converted here in France. One of the members who has converted several cars from rhd to lhd lives in Normany not that far from the Ferry Port of Le Havre. He speaks very good English also.
Fri Dec 20, 2019 1:13 pm
by mrfettler
Thanks vary much for all your reply's guys
Very informative and most helpful
Mon Dec 23, 2019 10:37 pm
by fattogatto
Are RHD Elans that rare?
Sun Dec 29, 2019 7:13 pm
by gino1
Dashboard
Pedal box
Steering rack
Lengthen wiring harnesses
Move clutch &brake cylinders
New clutch hose
Move handbrake cable and handbrake lever To opposite side
Open up new holes for steering column an clutch and brake cylinders- close existing holes on opposite side.
Gino
Mon Jan 20, 2020 10:54 pm
by crypto
You might need to swap / modify your ignition key lock too. I converted from RHD to LHD and modified the outer steering column. Maybe also the mounting bracket between steering column and dashboard.
I used the same hand brake handle mechanism from the RHD, but it turns in the wrong direction to release.
The RHD pedal assembly was re-used and modified for LHD. You might consider to make them further apart depending on your shoe size ...
Sat Jan 25, 2020 6:54 am
by Frogelan
Several other more obscure ideas...
Battery location (perhaps not with a S4)
HL vacuum switch / kit
Headlamp lenses
Fog lamp side
Personally I would leave it LHD as the resale market and places to drive it on the left are bigger...
