S3 Restoration
Certainly am, and would love for one and all to join.
Unfortunately a date cannot be set at the moment due to my car’s finish date being altered.
Will get a date in the diary very soon
- glennmoule
Glen,
I have always used the S2 wiring schematic, with additional small looms for the electric windows. All else is the same. I am also restoring my pre-airflow coupe 5526. I'm just about ready to re-install the body onto the chassis.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Thanks for the tip Roger, I will use it for sure.
My body is well under way and should be ready in a few weeks. I’ll post it’s current state now.
Looks like we will be completing ours around the same time.
- glennmoule
As of today, this is where my Elan body is at.
Doing the second panel and body fittings dry fit this week.
- glennmoule
Looking good Glenn !
Hope you're keeping well mate
- ROADRUNNER
Thanks so much. Things are moving forward quite nicely now.
- glennmoule
Engine and gearbox in.
I now see why the subframe lower cross member was changed to a removable one on later models. It is near impossible to get the engine and gearbox in while they are joined together.
If I ever need to remove them in the future I will most certainly be splitting them before removing.
- glennmoule
glennmoule wrote:Engine and gearbox in.
I find it is much easier to fit the engine and gearbox separately. I wasted several hours the first time I tried with the engine and gearbox together.
Malcolm.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Just to correct a detail that the Elan Chassis never had a removable Low Cross Member.
However the +2 did have a removable Low Cross Member.
I also fit Gearbox first then after fit Engine.
Stops the Bellhhousing Jam
- alan.barker
Looks great! Reassembling is the easy part. Keeping your fresh paint job from not getting scratched is the hard part. We won’t talk about the part you can no longer find and doesn’t seem to be available anywhere.........
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Users browsing this forum: crannyr and 17 guests
