My Elan S2 light pods go down on quick acceleration
I believe that the vacuum switch should only be tested by vacuum. The sliding rubber block is designed to seal under negative pressure and using pressure may/could/will force the block upwards against the flat metal spring, giving a false indication of a leak. The rest of the system can be tested by pressure.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
