Project Scruffy Thread
I bought it sight-unseen from E-bay during a momentary lapse of reason. It needs a ton of love, but so-far things have turned out better than expected. After fiddling with the wiring and hooking up an auxiliary fuel tank, I crossed my fingers and hit the key. Fired right up! Excellent compression. Idles fantastic, which is bizarre as I didn't touch the carbs. Water pump is moving coolant. No coolant leaks, but she does drip a bit of oil. I have to assume the engine has been rebuilt.
I'm currently installing a new clutch master and slave and car will receive new brakes and lines. Then we'll see if she moves.
Rolling restoration for now, as I have no garage space to dive in as deeply as I would like. Updates to come.
- elaninfuture
Excellent! Dripping oil only means it is British. When a British car stops dripping oil, that means its empty...
One drive and I am sure you will be completely hooked.
1963 Unicorn
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
- knockoffnut
"Idles fantastic, which is bizarre as I didn't touch the carbs."
Congratulations! That's great! Don't mess with them until you learn as much as you can about them.
Welcome to Elan ownership. Mine is very scruffy as well. Drive and enjoy.
Dan Wise
Dan Wise
knockoffnut wrote:Excellent! Dripping oil only means it is British. When a British car stops dripping oil, that means its empty...
LOL
Welcome to the mad house.
Rolling resto is absolutely the way to go, but I'm slightly concerned about the no garage bit. A large umbrella is better than nothing, but there are so many put-up covers that would work well.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Thanks guys. It's going to be a while before it's on the road. One step at a time. I do have a garage to work on the car, Graeme, but it's too full of other cars, bikes, lawnmowers, etc. to allow space for a serious restoration.
Joe
Joe
- elaninfuture
StressCraxx wrote:"Idles fantastic, which is bizarre as I didn't touch the carbs."
Dan Wise
Problem is, the best way to learn is to mess with them - agreed, when Webers work as they should, they are a delight.
- Slowtus
Joe,
So great to hear you're doing this. This is what I had to do to my coupe, since I bought it to drive, knowing the paint was poor, but it would allow me to continue to drive an Elan.
Once its running on its own fuel tank, drive it and enjoy it. Use polishing compound on the body and you will find it very satisfying and lots of positive comments. Check the donuts as you go through the brakes.
5526 is finally in the shop I lobbied for over a year to do the job. I didn't make it in yesterday to see it before Christmas, but I was told it would be in primer, 2nd coat, by end of day yesterday. The new year will start with with 5526 back home and going back together. It already has red under the arches.
I had never seen you archive page before, so I checked and both 5525 and 5526 shipped to Duchess Auto same day on same invoice number.
Welcome back! Anything I can help with from 1500 miles away, let me know.
Roger (in Florida)
Roger (in Florida)
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Joe,
I too would like to offer a word of encouragement. I can assure you that the effort will be worth it once you can get on the road. Don't worry about aesthetics just yet, make her roadworthy and drive as much as you can to bond with her and let us know how it goes. We have mostly all been where you are and come through the process with joy at the end. I think you will too!
Cheers and Merry Christmas!
- Ross Robbins
Thanks for the encouragement, guys. And thanks to the board. I'm not sure how people did this stuff before the internet.
Joe
Joe
- elaninfuture
Go for it! You?ll never regret getting your coupe road worthy and driving it for pure enjoyment.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
