New member from South Africa
My S2, unfortunately not complete, engine had to be re stripped as it had been not been started for so long.
still have to source window scissor lifts, inside door handles, door pads and arm rests, hood, boot lock, headlight switch, bonnet pulls and catches etc etc. will be fitting twin cone air filter away from the radiators path, radiators out here don't like anything in the way.
Engine not what was originally fitted, re built from a Lotus Cortina, longer con rods fitted, hopefully give a bit more torque. Seats are not original either Cobra classic with built in headrest.
First question I want to upgrade from the generator to alternator, appreciate any help / changes I need to do.
I hope I can pick a few knowledgeable brains in the months to come.
- SA Elan Esprit
Welcome! A switch from generator to alternator also means a switch from positive ground to
negative ground. The tachometer is the only worry here. There are many ways to convert
the tach; On my S3, I simply gutted it and replaced the innards with a modern 'off the shelf'
tachometer. A bit tricky getting the needles off and on. There are many threads here on
converting a tach. Good luck.
Greg Z
45/0243K Sprint
36/5727 pre airflow coupe
45/0243K Sprint
gjz30075 - Coveted Fifth Gear
For the tach modification, go to mossmotors.com, and look in their tech articles. The modification from positive to negative ground can be found there. The modification can be done at home, if you wish.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Welcome SAEE! Looking forward to seeing more of your progress!
1969/70 Elan Plus 2 (not S) 50/2036
The Veg - Coveted Fifth Gear
SAEE,
Welcome to the best Elan Forum on earth!!!
There is nothing better than seeing an early Elan going back together.
If I can help, let me know. I manufacture Exact Reproduction S1 and S2 Door Arm Rest Pads along with other interior components. 10% off to Forum members.
Famous Frank
66 Elan S2 SE
65 Elan S2
66 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
66 Elan S2 SE
65 Elan S2
66 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank - Fourth Gear
