elan S2 1966
I am listening to you, on the ideal choice of rear shocks for Elan S2 in normal use. Make your comments, it can also help many of us!
I am looking for these parts:
- back shocks
- the sheet metal part of the air box attached to Webers- Elan S2 1966
- rear light Elan S2 1966
- clevis = JF11 (see drawing on the workshop part manual) attach to the end of the handbrake cable rear(at the pivot to the frame)
If you can help me
geni
- back shocks
If you can help me
geni
- geni
Bonjour,
as for shocks, I'm quite happy with my standard red Konis : for mixed use I've set them up a bit stiffer, but for as original road use you may set them on the soft side
for new parts supply there are several options in the UK, I mostly keep with the services offered by Sue Miller, Tony Thompson or Kelsport (ex. Pat Kelvedon), e.g.
air box plate late type
http://www.kelsport.net/parts/product_d ... ctionID=66
early type
in fiberglass
lighting (not sure which type you refer to, and if/where the long type is best reproduced)
http://www.kelsport.net/parts/products. ... ctionID=42
brake clevis
http://www.kelsport.net/parts/product_d ... ectionID=2
no affiliation of my part - happy shopping...
early type
in fiberglass
brake clevis
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Standard Elan shocks (dampers) were Armstrong I believe. Konis, Spax and Gaz are your other options.
1963 Unicorn
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
- knockoffnut
