Restoration
Wed Jul 26, 2017 8:27 pm
by shaun
Rear suspension trial fitted
Re: Restoration
Wed Jul 26, 2017 10:22 pm
by 1owner69Elan
Looks great.
What size wheels are those? What body is going on eventually ?
Re: Restoration
Thu Jul 27, 2017 4:50 am
by shaun
The wheels are minilites 5x13 a s4 Dec body will be used when back from the body shop
Re: Restoration
Fri Jul 28, 2017 7:53 pm
by Mr.Gale
Looks good! Did you install a Diff. cover stiffener?
Mr.Gale
Re: Restoration
Sun Jul 30, 2017 12:07 am
I see you don't have the rear Aeon rubber springs fitted and I presume the small diameter springs are to small for them to fit inside. These rubber springs are a key part of the original suspension design enabling the combination of soft ride with good handling through the progressive spring rate they achieved in the rear suspension. There is a VW Audi part that has a similar length and spring rate to the original Aeon rubber springs but a smaller diameter that others have used.
Re: Restoration
Sun Jul 30, 2017 4:27 am
by Davidb
Part # 171 412 303 c
Get it on ebay.
Re: Restoration
Sun Jul 30, 2017 10:41 am
by shaun
Thanks for the advice , so even with matched dampers and springs the suspension still relies on the rubbers thanks Shaun
Re: Restoration
Sun Jul 30, 2017 11:25 am
shaun wrote:Thanks for the advice , so even with matched dampers and springs the suspension still relies on the rubbers thanks Shaun
Unless you go up to race track spring rates you need the added spring rate that the rubber spring provides at the rear. With standard springs and no rubber spring you get the tail sitting down in a corner on the outside rear and the front inside wheel lifting to much. Typically this results in unpredictable oversteer in a corner taken hard.
Re: Restoration
Sat Nov 04, 2017 3:39 pm
by shaun
Never make a machinist , 4 hours and a bit of finger milled off
Re: Restoration
Sat Nov 04, 2017 6:55 pm
by dougweall
Shaun,
I can see that you are going to produce a very nice car the way you are going.
Now I don't want to p155 on your bonfire but I know a couple of folks near me who have tried fitting 5" rims to their Elans and fallen foul of the tyres catching the wheel arch. It is possible to relieve the arch to make them fit, but you will have to be very careful once your body is painted.
Unless of course you have trial fitted everything first.
I was lucky when I bought my Minilites, only had to sort out the bolts on the rear bottom wishbones to clear the wheels, the arches were ok.
Doug.
Re: Restoration
Sat Nov 04, 2017 7:52 pm
by Foxie
I see you're using adjustable rear wishbones. That was one of the best improvements I've made to the car's handling. On the originals, one wishbone was positive toe, and the other negative, and overall positive, bit of a disaster
Re: Restoration
Sat Nov 04, 2017 11:26 pm
by bitsobrits
The issue with the 5" Minilites available now is not so much their width, but that their offset is greater (more positive) than the 4.5" stock rims. On my S3, the Minilite inboard tire mounting bead surface was greater than 5/8" further outboard than the stock rims, which puts the outboard bead surface of the rim a full 7/8" further out. So no go (on my car at least) without significant surgery.
Apparently at one time Minilite offered a more negative offset option (114mm I think), but now only supplies the 100mm versions.
Re: Restoration
Sun Nov 05, 2017 1:46 pm
by TurbineHeli
I'm curious about that adjustable feature on your rear wishbones.
Wouldn't any adjustment other than neutral(original) place strain on the wishbone
in either tension or compression? Or is the amount small as to not matter?
Re: Restoration
Sun Nov 05, 2017 5:53 pm
by TeeJay
On a lighter note, just noted the most important tool, on the first photo, especially useful for the many times you go 1 step forward and several back, a wine glass.
It's by the front left side wheel and it's empty, must have been one of those days.
Regarding the machining, you could have spent more hours searching online for the part and its very satisfying making your own.
Hope the fingers OK.
Re: Restoration
Sun Nov 05, 2017 7:56 pm
by TurbineHeli
Also visible in 3rd pic...
