glue for rear view mirror
hi all
have searched the archives without success....the rear view mirror on my s4 has just fallen off....can anyone recommend a suitable glue for re-attaching?
thanks!
fred
thanks!
fred
'Never give up!....unless it's hopeless.....'
1970 S4 dhc big valve
1973 Ginetta G15
1967 Ginetta G4 [sadly now sold]
1959 lotus elite type 14
1973 Ginetta G15
- Elanconvert
I just use ordinary superglue but do have to re-stick my mirror about once a year. I have tried all sorts of 'specialist' glues and none seem to work for very long, especially when there is a large change in ambient temperature. I would avoid any 'flexible' glues as the rear mirror wobbles around so much it's impossible to get a clear view of what's behind you - I tried some sticky mounting pads once and discovered this the heard way..
pereirac - Coveted Fifth Gear
Almost an annual event in my Sprint - usually falls off just before MOT......I use 3M double sided tape - works a treat for about 12 months!
Martin
Martin
- martinbrowning
I use transparent epoxy. The one you will find in any DIY market, in two small tubes which you push simultaneously, so proportion is nearly perfect. It is very transparent, you do not see anything from the outer side. If you use too much or when pressing surplus (if not too much) is easily removed with a cutters blade.
So strong you need not to worry falling off ...
worry only if you want to remove it case you want to change wind screen
1964 S1 (at paint shop)
1967 S3 DHC
1969 S4 FHC (at BB's home)
1967 S3 DHC
- gherlt
ok....thanks for the tips guys.....
I had seen the 'specialist' stuff, but was also advised that superglue was the way to go....
fred
fred
1973 Ginetta G15
1973 Ginetta G15
- Elanconvert
I would echo the glue specifically designed for that, one car I bought had it put on with something else and over time it cracked a very nice circle right around the glue point. The only other thing is that my S3 has the rearview mirror mounted on the metal rod and my +2 has it screwed into the roof area, did Lotus even mount them on the windshield? Gordon Sauer
- Gordon Sauer
I glued a day/night rear view mirror on the windscreen of my S2 Elan back in the early 1970s using the Loctite product. It's still there.
Herb
26/4618
26/4618
lotusS2guy - Second Gear
pharriso wrote:jono wrote:http://www.halfords.com/motoring/paints-body-repair/adhesives/loctite-rear-view-mirror-adhesive-kit
Used this before, it's permanent
Yup, that's it, don't mess around with anything else...
+1
Think it was Phil who recommended it to me a while back, since then i've used it on at least ten cars now and never had an issue with it. Whats more is it's very clean and mess free (doesn't ooze out all over the place and doesn't discolour)
For what it costs don't mess about....
https://www.youtube.com/watch?v=CsdP6CMCxr8
Grizzly - Coveted Fifth Gear
pharriso wrote:No not Silicone! Parts stores carry an adhesive specific for this task by 3M or Loctite
Any reason why not to use silicon? I've used "sanitary silicon" to fix car mirrors before - it's a good "filler" if there's nothing behind the mirror to glue to
sdenny - First Gear
