Mine is LHD 26/0345 manufactured in 12/23/63, and confirmed by Mr. Mike Pomfret that it was shipped to a US dealer called Lindner that year.
- Nobuyuki Chris Yamada
Hi guys
this is the correct grey colour, slightly lighter than 0202 engine bay! As you all know the colour was actually a grey pigment in the gelcoat and not a painted surface, the Bourne shells were grey all over!
Jonsered
Jonsered
- jonsered 11
I have a Bourne car. The Bourne car body was made with grey gel-coat. The engine compartment was not painted . My car is currently undergoing a rebuild/restoration, and I soda blasted the body and the original grey is very apparent. I covered all the markings on the body and frame before the blasting and repainting. The grey in the engine compartment has yellowed with age, chemicals and heat, but I plan to leave it as is.
Look at the Elan Registry for other diferences.
'61 Elite 1865
'63 Elan S1 25-0269
'61 Elite 1865
'63 Elan S1 25-0269
- Lotus14S2
Hi, I am new to the forum, I own chassis number 281 which is Bourne body 26/0298.
- chrishawkins
Welcome Chris, lovely car.
I think we are up to about a dozen cars so far, there must be more out there...
David
David
David Rose
1963 S1 - Bourne bodied
1965 S2
1966 S3
1969 Europa - 210bbhp by Banks
1965 S2
1966 S3
- dunclentdr
I am still slightly confused about when the Bourne run may have ended - would chassis 26/0410 be a Bourne car? Is there a clear view about the chassis number at which things changed over?
David
David
David Rose
1965 S2
1966 S3
1965 S2
1966 S3
- dunclentdr
Hi David,
there doesn't seem to be any clear change point from Bourne shells to Lotus ones!
Even Andy Graham has no records showing it? Of the three cars that I have,body number 205 is the latest, registered in October 63, although clearly as we have seen here there are some in the 300s, in fact a friend of mine has one in the late 300s, however it is unlikely that chassis number 26/0410 would originally have a Bourne body, but you never know?? Does that chassis number not have a bodyshell that you can view, as there are lots of small differences between the two, apart from the obvious grey gel coat!
Jonsered
Jonsered
- jonsered 11
Thanks - not able to view the car at the moment and assume, as you say, it is probably a later car.
Apart from the grey engine bay etc what are the other little things to look out for?
David
David
David Rose
1965 S2
1966 S3
1965 S2
1966 S3
- dunclentdr
I still get confused reading this - to me, a 'Bourne body number 26/001 onwards' is a chassis number like 26/0202. If you follow this then 26/0410 would be a Bourne?
David
David
David Rose
1965 S2
1966 S3
1965 S2
1966 S3
- dunclentdr
David, please read my post on page 1 of this thread, which explains the differences in Lotus terminology.
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
Thanks - all becoming clearer.
For my two cars I have the following:-
Car 1
Unit 3217
Chassis 26 0202
Body number 0252
Car 2
Unit 3324
Chassis 26 0339
No body number
Is it possible to track down the body number anywhere? Not sure if these were recorded?
David
Car 1
Unit 3217
Chassis 26 0202
Body number 0252
Car 2
Unit 3324
Chassis 26 0339
No body number
David
David Rose
1965 S2
1966 S3
1965 S2
1966 S3
- dunclentdr
Hi David,
Andy Graham has a list of some body numbers! He may have one for that chassis, if you're lucky!
Regards Jonsered
Regards Jonsered
- jonsered 11
Users browsing this forum: Pastapesto and 50 guests
