Screen washer Switch / Pump
Maybe there is an alternative here...
http://www.jamespaddock.co.uk/parts.asp ... her%20pump
I fitted item 155495 to my +2 and it works well.
- KevJ+2
They are based on a Ford wiper / manual washer switch, like this one:
http://www.ebay.co.uk/itm/1-vintage-Cor ... SwU-pXuKkx
Some will be a direct swap, others may have to be fettled a bit. The Anglia electrical switch is I believe only one speed, but maybe you could build one good unit out of two using your original switch.
Here's another...
http://www.ebay.co.uk/itm/Anglia-105e-w ... SwCGVX5~la
Here's another...
Don't forget about the check valve. In Europas, it's attached to the end of the pick-up tube inside the Tudor reservoir bag. The pump itself may be okay.
I have a spare switch/pump from a Europa, but I don't know if it is identical to the Elan one. Two-speeds for the wipers, and the manual push on the knob to pump fluid to the windscreen. PM me if you think that might work for you.
Steve in Ohio
Steve in Ohio
- sveris
One just popped up on ebay if you still need it.
http://www.ebay.co.uk/itm/Lotus-Elan-S1 ... SwzaJYBUpR
