Re: 45/6994 Elan S3 Rebuild
Tue Mar 24, 2020 12:01 am
by ethanlance
Sorry I have not updated in a while. Tons of progress. She’s back together. And now I’m focused on detail work, interior, etc
attachment=0]39BD6E51-64C7-4AE9-9860-A928153259A1.jpeg[/attachment]
Tue Mar 24, 2020 7:27 am
by S3FHC
Hi Ethan,
what a beautiful car!
we need more photographs like this to lift the gloom....
Tue Mar 24, 2020 5:25 pm
by snowyelan
Beautiful. I may have missed it but if not could you share the color/paint code? I'm set on blue for mine, just not sure which.
Tue Mar 24, 2020 10:42 pm
by ethanlance
snowyelan wrote:Beautiful. I may have missed it but if not could you share the color/paint code? I'm set on blue for mine, just not sure which.
The small can of paint that came back from the paint shop reads “PPG Omni Base 18446 + Black”
We just picked a blue from a chip that looked close to an official blue color.
Wed Mar 25, 2020 10:58 am
by ROADRUNNER
Really enjoying following your progress. I think you'll be pleased with the colour. This is mine.
Mon Nov 02, 2020 11:23 pm
by ethanlance
PSA as we head into wet season I wanted to remind people to replace old tires. This embarrassing episode happened to me last February 2020.
What happened? While testing my brand new suspension and more powerful motor, I just ever so gently goosed the throttle around a canyon curve... but still on OLD TIRES... and I shot myself nearly over a cliff!
Long story short. The car has zero damage, it sunk into the mud (that's a long way down otherwise). Some good samaritans helped me out and the CHP chewed me out!
I got new tires immediately, 145HR13 PIRELLI CINTURATO ™ CA67 from Longstone.
And I have not gone over a cliff in 8 months!
Tue Nov 03, 2020 12:09 am
You are lucky to be alive, let alone zero damage!
Tue Nov 03, 2020 12:14 am
by Sploder90
Wow, lucky escape. Glad you and the car came out intact
Tue Nov 03, 2020 1:10 am
by The Veg
Wed Nov 11, 2020 5:44 pm
by lowflyer
Lucky escape indeed. I learned my lessons a few years ago on Caterham 7s: check the dates and make sure you can get enough heat into the tyre with the replacements, especially if it's a lightweight vehicle.
You selected a great colour too, which works well in light and shade. But then I am biased
Wed Nov 11, 2020 8:47 pm
by h20hamelan
From a tower's perspective. The recovery truck was a 5 degree angle flat deck. No side puller that could get to 15 or 45 degree angle, not even the 75 degrees required for such a pull. Therefore, the resistance put on your frame/chassis is major, and well beyond allowable parameters. There is never a case to use a deck truck for anything more than 5 degrees. I would be irate at that towing company for using the incorrect truck. Secondly, and the important part. Is your car. The angle your car was at, vs the angle of pull has no doubt put an incredible strain on the chassis. I would have a body-off look, and measure. If the "required state laws" say you must report to a structural and alignment body shop for confirmation the chassis is straight and true. After such an accident, here in BC we are required to.
My guess is a 1,700 car, at a 75 degree angle is well over 2,000lbs. Now factor in resistance, you said it was stuck in sand/mud. Add another 15-20% minimum. Now you have to overcome the angle, like said 75 degrees is the correct pull angle for this recovery.
The point here is, when you start pulling straight from the side of the road, you are pulling close to 4,000lbs. The winch line on his truck is a maximum working load limit. Your chassis is well beyond.
I only have the pictures provided to confirm this. I have high angle rope certification, swift water rescue, and wreckmaster cert too. And 30 years of practice.
Glad you and beauty car are okay, please check chassis!
Tue Dec 08, 2020 10:34 pm
by ethanlance
lowflyer wrote:Lucky escape indeed. I learned my lessons a few years ago on Caterham 7s: check the dates and make sure you can get enough heat into the tyre with the replacements, especially if it's a lightweight vehicle.
Your's looks great. Love the color.
Tue Dec 08, 2020 10:35 pm
by ethanlance
Sounds like something I would do
Tue Dec 08, 2020 10:53 pm
by ethanlance
My latest weekend project and the second time this year she stranded me on a backroad.
Front-outer wheel bearing. Not sure if I should categorize this as a mechanical failure or a mechanics (me) failure. Hah. Did I somehow not pack this with grease!? Anyway, it's fixed now.
Ended up pulling both front wheels to check and re-pack bearings.
And here she was, looking sad, not even able to limp home.
