Every beer should take a lesson from this site. Marvelous.
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
fattogatto - Third Gear
pharriso wrote:Should not be a problem https://www.beermenus.com/beers/8111-marston-s-pedigree
One of my favorite beers as well...
Phil, I'm very impressed. And that's not easy to do with me
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Actually, somewhat depressing. The closest bottle seems to be in Cleveland. Back to my Arrogant Bastard Ale.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Todays plan was to get the freeze plugs installed and the engine back in the Elan.
Fired up the propane heater at 6am to preheat the garage and Drew showed up at 7am sharp. We talked about world events (depressing) and our professional lives to catch up since last week and then focused on the objective at hand.......
The block openings were scraped and then cleaned with lacquer thinner with Dow Corning high temp sealant applied before the plugs where installed. All went according to plan with all the plugs both in the block as well as the head. .
Of course the engine didn't quite line up right away with the trans input shaft. That took a couple of hours to finesse to get just right.
Once the TC was installed and bolted up, we focused on all the parts that need to be re-attached to the engine.
Drew had bead blasted the SOVY can during the week and found pin holes in the can. He soldered the holes and then cadmium plated the can. Looks great and is installed with the new cap.
After Drew left I worked on the Elan for a few more hours. It was a two Ale day
Glen
Certified Lotus wrote:Drew had bead blasted the SOVY can during the week and found pin holes in the can. He soldered the holes and then cadmium plated the can. Looks great and is installed with the new cap.
So you now have my repaired SOVY can & I have TerryP's
Well done, you're making good progress!
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Phil, greatly appreciate your SOVY can! I wanted to restore this S4 to as close to OEM as possible. Everything is coming togther nicely. This will be a great Elan when I'm done
Glen
I'm at the point that the details are important. You know, this little things that get looked over because your excited to get the Elan back on the road. And some of them take some major thinking and redoing.
I decided that I was going to keep this car as close to stock as possible. So one of the major issues was the air box with the weber carb/throttle return spring. Despite wanting to keep this car as close to stock as possible, I refuse to install rubber fuel line. Only braided fuel line and aluminum fittings are used on any of my cars. The braided fuel line requires some extra clearance so a portion of the air box bracket is ground out in a curve to make plenty of room for the fuel line without rubbing.
I had ordered a new throttle return spring and of course the size of the spring diameter and the holes in the air box bracket and the weber throttle control were all different. That meant removing everything I had just installed and drilling out the holes so the spring would fit. Hours of labor, thank goodness my friend Drew is here to help as no short cuts for me.
Another thing I notice while the radiator was out (I had it professional cleaned out and pressure tested) was the steering rack brackets seemed cocked. When I dismantled the brackets I noticed the shims were not correct for this car so I ordered new one and installed them on both sides.
I went about draining the transmission and differential oil and replaced both. Drew worked on replacing all the vacuum lines for the headlights. I had ordered all the correct parts from RD Enterprises so we were well prepared.
Finished installing the radiator, hoses and all the brackets for the cooling system. Filled with anti corrosion anti-freeze.
Installed the rebuilt starter motor and the generator. Replaced the bolts, nuts, washers with grade 8.
Installed a few new grommets in the engine bay (the old ones were dried out and cracked).
Bolted the exhaust system back in and lowered the car onto the ground calling it a day. We didn't get as much done as anticipated. People kept stopping by to see what was going on as the word is out we are restoring Lotus sports cars in my garage. It was also a 62 degree F day in mid-December and the weather is bringing everyone out !
Next week is tracing out all the wiring in the electrical system. No idea how long that will take, but I'm well prepared......I had a copy of the wiring diagram made 4 times larger than normal so tracing all the circuits would be easy
Glen
No doubt the person buying this Elan will be getting a quality product!
Good job Glen (and Drew)!
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
Thanks Chris. We are very focused on getting it right. When we are done it will be a great road car for a Lotus Elan aficionado who wants to drive the car and not restore it. Of course, it's a Lotus so there will always be some thinkering to be done along the way
Glen
Certified Lotus wrote:John, I don't think I have ever had Marstons Pedigree. Will need to see if I can find it here in the States. Thanks for the recommendation! I like keep the garage fridge full of interesting ales to enjoy after a long day of Lotus work
Update: I went to three different liquor stores that stock hundreds of beers and ales from around the world. No one carries Marstons. Unfortunate. Now I have to wonder what I am missing
I had one in your honour this weekend:
Glad to report still superb!
Looks like the work is progressing really well!
Phil Harrison
That's tempting Phil. I need to get to the beer store you located for me to get a case of my own. Just need to find the time to drive 28 miles each way.
Maybe it will add some motivation to get done by New Year............
Glen
OK, first the important stuff. John, thanks for introducing me to Marstons Pedigree ale and Phil thanks for finding the closest location to me to purchase it! I made the 2 hour round trip early Saturday morning and I can tell you from my tasting late this afternoon it was well worth it!!!
Today was scheduled to be electrical wiring tracing gremlin day. I had already made a large copy of the wiring schematic to trace every wire and test them. Drew and I pulled the dash out as far as we could, removing the oil pressure line, speedometer cable and the stick shift. We put a blanket down underneath the dash so it would not get scratched and Drew was armed with an ohm meter, test light and flashlight while I read the wiring schematic as we traced wires and tested for continuity as a team. It was laborious and required a bit of sleuthing as not all the wires were color coded appropriately. Over all we got through most of it with only a couple of head scratching moments where we need to come back and decide on some solutions.
One of the things we cant figure out is the connection block attached to the headlight vacuum switch. I cant seem to find this in any documentation. Can anyone provide some insight to this?
Chris came over to use my parts cleaning tank as he is disassembling a differential to rebuild for his S4. We later got into the finer points of discussing what parts should be replaced while the diff is apart.
My wife and oldest son Ryan came out in the garage to see what we were up to. Ryan stuck around as he realized he could learn something from the "old guys" about reading a wiring schematic and tracing wiring. Ellen just made a rare appearance in the garage to see what we were up to and were we ever going to finish this project
Half day today. Drew, Ryan and I went to a garage in the next town that is going out of business to buy some used equipment. Early Christmas for me
Well, I've got a case of Marstons Pedigree in the garage fridge and some great friends and a wonderful family. And two Elan's in the garage. Life is good!
Merry Christmas everyone!
Glen
Very nice job and clean engine bay. You don't have any clearance problem when opening the hood with the engine fan ?
Almondgreen - First Gear
That is a good question Almondgreen. I have never had the bonnet on the car. It was delivered with it off as this bonnet does not have the bulge for the carbs on it, it's flat. I know it's never been fitted so I guess I will find out. I had just assumed the fan layout was from a Sprint.
Glen
Almondgreen wrote:Very nice job and clean engine bay. You don't have any clearance problem when opening the hood with the engine fan ?
The fan installation looks like the standard Lotus installation in terms of motor and bracket though the fan blades look different from what was fitted to my 73 Pus 2. But maybe the blades changed over time.
