PostPost by: seniorchristo » Wed Mar 02, 2016 12:48 am
Congratulations Guys!! Whopee!! Another successful rebuild almost complete! I can't wait to get over to see the results in person. You better be careful letting Drew drive. He might not let you sell it.
Later
Chris :)
67 Elan Super Safety
67 Elan +2
PostPost by: SF69Elan » Wed Mar 02, 2016 4:31 am
Really appreciate all the details of your rebuild that you've posted here - and what a great looking result!
"What kind of a man are you? Don't you even like dolphins!?" - Zorba the Greek
69 Elan S4/SE DHC
66 Ford Mustang Conv. (289ci)
71 Cadillac Eldorado Conv. (8.2L)
65 Buick Wildcat Conv. (425ci)
And a pickup truck full of Miatas....
SF69Elan
PostPost by: CBUEB1771 » Wed Mar 02, 2016 6:51 pm
Certified Lotus wrote:The weather gods smiled upon us today. It was 60 degrees F by noon with sunny blue skies and no wind. It's the end of February and its almost unbelievable. This is convertible weather. Time to finish up the S4 !
I flew from Boston to Baltimore late on Sunday morning and looked down to see if you were working as we passed over Princeton. Unfortunately Elans are had to pick out from 34,000 feet but the weather did look great.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: Certified Lotus » Thu Mar 03, 2016 12:21 pm
Chris, another month and we should go for a drive together ;-)
Thanks SF69Elan. I am am hopeful that my posts are an inspiration to all those that have "project cars" in their garage.
Russ, let me know next time your flying over, I'll arrange for a beacon so you can spot me ;-)
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Certified Lotus
PostPost by: Certified Lotus » Sun Mar 06, 2016 11:47 pm
The rebuild list continues to get shorter, but as usual some missing part is needed to finish a task at hand.
I had ordered new locks for the doors and the boot as the keys didn't work and that would drive me nuts. Ray at R&D had what I needed in stock and shipped them straight away. I wasn't worried about replacing the boot locking handle, that seemed simple enough......and it was. Although I looked at a number of photos of cars to determine if the locked positon is up or down. I couldn't tell which was right so I picked locked up as it doesn't interfere with the license plate.
dsc07792.jpg and
Original boot locking handle and lock
dsc07794.jpg and
new boot handle and old comparison
I had also ordered a new rear view mirror from R&D as it was the proper type and the back was gold which will match the bumpers!
dsc07810.jpg and
New rear view mirror
Drew pulled the head/valve cover while I was working on the locks to check the cam shaft to valve clearances. Everything was to spec.
dsc07808.jpg and
Checking valve adjustment
He then replaced all the distributor to spark plug wires and coil wire with a new set (the old set was more than 15 years old).
dsc07814.jpg and
Replacing distributor cap wires
dsc07820.jpg and
New spark plug wires
I was deep into the replacement of door locks. Not much in the way of instructions in the Lotus shop manual or Bucklands book. A couple of posts on this website said it was a total pain to do......but I persevered. The removal of the locks themselves is interesting as there is alomost no space to put a wrench inside the door with the window installed. I came up with the brilliant idea of using a plumbers wrench to remove the locking nut on the back of the door lock and it worked perfectly!
dsc07819.jpg and
Replacing door locks using plumping wrench
I was reassembling the door mechanisms and realized I was missing a door rod clip. Damn! one small little part prevents me from finishing the door card install. Another R&D order (sorry Ray, the parts orders are getting smaller and smaller).
The rebuilt generator hasn't come back from the shop, but that should be next week. Unfortunately my schedule is packed the next couple of weeks and so is Drew's so we are probably not working on the S4 again until April (at least that's what we put in our calendars). But that is OK, we are close to completion and it will be warm out in April for more test drives :-)
Glen
Certified Lotus
PostPost by: Certified Lotus » Wed Mar 09, 2016 2:51 pm
Rebuilt generator and door clips. Now I just need some spare time!
image.jpeg and
Glen
Certified Lotus
PostPost by: pharriso » Wed Mar 09, 2016 3:34 pm
Certified Lotus wrote:The rebuild list continues to get shorter, but as usual some missing part is needed to finish a task at hand.
Well you proved Murphy's law... 50:50 & you were wrong... The long part of the lock handle should be down with the lock latched... :roll:
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: Certified Lotus » Wed Mar 09, 2016 11:26 pm
Figures. Where were you when I was installing the boot handle Phil? Another fix back on the list!
Glen
Certified Lotus
PostPost by: Certified Lotus » Sat Mar 12, 2016 11:03 am
It's the details that count! Sourced the bracket that holds the pin to keep the glove box door closed. Will media blast and repaint.
image.jpeg and
Glen
Certified Lotus
PostPost by: pharriso » Sat Mar 12, 2016 12:04 pm
Certified Lotus wrote:It's the details that count! Sourced the bracket that holds the pin to keep the glove box door closed. Will media blast and repaint.
Where on earth did you find that??
Phil Harrison
PostPost by: Certified Lotus » Sat Mar 12, 2016 4:41 pm
I've found a source that seems to have almost everything I'm looking for. Amazing. Expensive but amazing.
Glen
Certified Lotus
PostPost by: 1owner69Elan » Sat Mar 12, 2016 6:22 pm
img_5624.jpg and
img_5623.jpg and
The glove box latch on my S4 is much different (45/9182).
It says "Limread Tutch Latch". It's a spring loaded affair.
This is the original equipment, as I am the original owner.
Forgive me, but the latch you have looks a bit "home-made". But perhaps it is correct as your car is a bit earlier than mine.
If it works, great.
'69 Elan S4 SE
Street 181 BHP
Original owner
PostPost by: pharriso » Sat Mar 12, 2016 6:55 pm
If it works, great.
Glen & my cars are identical, maybe just federal late S4 & Sprint?
Phil Harrison
PostPost by: Certified Lotus » Sat Mar 12, 2016 9:48 pm
1owner69elan, interesting glove box catch you have on your car. I now have a sample of two types to reference. Can anyone else provide a photo of their glove box latch system? I'd like to know what is "typical" ?
Glen
Certified Lotus
PostPost by: 1owner69Elan » Sun Mar 13, 2016 7:04 pm
I happened to be looking at my 1969 parts manual (obtained directly at the factory at the time I picked up my car)..
The "Tutch Latch", part no. 036 B 6150, is referenced for the S4 from car no 7895. So, in theory, as we know not everything is consistent with the Elan, the touch latch would be appropriate for your car no. 7941.
A quick google and it looks like these latches are still available new:
http://www.hafele.co.uk/shop/p/automati ... 12048/9610
This looks identical to the OEM one I have. Includes the catch that attaches to the door.
This a push touch type latch, no handle on the door. Push close, push open.
'69 Elan S4 SE
Street 181 BHP
Original owner
PreviousNext
