Elan S4 1969 restoration
I just discovered that my elan has a mechanical brake light switch above the pedal...Does anyone know of a picture or post one where I must mount the 3 way splitter for the front brakes?
Thank you
Willem
Thank you
Willem
- Sandals man
Willem
I have an US specs S4se (1968), and wanted to share a bit on this "tandem" girling master cylinder, in case it may be of use to you :
mine is a 0.70" ( ~ 1/16 ) bore girling # 64068928, repair kit 2610
These master cylinders have a reputation of being difficult to bleed, and I've have been doing so tilting the car up and down, sideways etc... for I've been chasing bubbles around for a long time on a occasionnally squeashy pedal, only to realize that this master cylinder has a valve at the front end : I now believe that my intermittent soft pedal symptom comes from a tiny bit of something moving around the sealing of that valve (will take off the master cylinder later this month to check).
good luck !
mbell wrote:If it was originally a US market car it would have had dual circuit brakes to meet federal requirements.
One connection goes to the front brakes, one to the rear. So the spare three way you found is probably for the front brakes. The rear will have one a 3 way near the rear of the car.
good luck !
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Hallo everybody,this is the sandals man from holland.I will appreciate very much if you can help me.I brougt my twin cam engine to the rebuilding shop and now he asked for more information about timing.He can not read english ...On the sprocket wheels there is one stripe so they must be C type.Where must I look for on the sprockets to see if they are inlet or exhaust sprockets.They can only be mount on one way ,than I turn the marking stripes on the sprockets horizontal ( like on the pictures)and than the crankshaft on time .Is this well done?Chassis nr 45/8859 stromberg head Car from us.
Thanks for helping
Willem
Thanks for helping
Willem
- Sandals man
Hi Willem
The C type cams have one groove on the hub that the sprocket wheel mounts on. The groove on the sprocket wheel that runs radially on its outer edge is used for setting up the timing per the diagrams in the manual or the Wilkins twin cam book.
Normally the exhaust sprocket has "Ex" etched on it somewhere on its front face. Sometimes the inlet sprocket has "In" on it but often it is unmarked. If both your sprockets are unmarked then check to see if the dowel pin position is different on the two sprockets versus the teeth. if it is, then we can probably figure out which one is the exhaust and which the inlet or if no difference whether you have two exhaust or two inlets - some photos would help.
Hallo Roan,the camshaft sprocket wheel has EX carved on it.I post the photos and thank you very much for helping
Willem
Willem
- Sandals man
Hallo Roan the pictures.Am I right if I say I mount the sprocket wheels turn the marking stripes so they stand next to each other horizontal,the crankshaft on marking stripe and than attach the chain?
Thanks for helping
Willem
Thanks for helping
Willem
- Sandals man
Hello everybody,this is the sandals man from holland.I am putting the overhauld engine in the chassis and have some questions.The fuel line in the rear goes over the chassis or under the chassis between the crossmember and diffrential???
The barrel and olive (3x) of the vacuum adaptor are missing ,where can I get them?
Where can I get a pipe with a barrel for the petrol pump for connecting a hose that goes to the stromberg carburettors?
Thank you
Willem Holten
Thank you
Willem Holten
- Sandals man
Willem,
First, the easy part of your question. The fuel line is correct the way you have pictured it.
Re your fuel pump. You will be aware that you do not have the correct item, so can you be sure that the pump you have, will deliver petrol at the correct pressure? Secondly, if you are going to use that pump, I notice that you have not used any lock washers under the bolt heads that secure the pump to the block. You should.
Lastly, as you do not have the correct pump, it is difficult to point you in the right direction as to where to obtain the pipes and olives for the pump you have, as the sizes may well be different to the original item, but you could ask your fellow Nederlander here, arno at caterham dot nl
Leslie
Leslie
- 512BB
Hallo Leslie,thank you for the reaction.I bought the petrol pump from SJ.Can you tell me what is wrong with it ?I can not understand they sell the wrong one fot twin cams.The barrel and olive I am looking for is for the vacuum nipple yoy see on the picture,any idea who sells them?
Willem
Willem
- Sandals man
Willem,
If you bought it from SJ in the UK it will no doubt work, but it is not the correct pump. I shall post a picture of the right one tomorrow. Forgive me, but your one looks HORRIBLE.
Send a message to Arno with the mail address I gave you, he may have the barrel parts you need.
Leslie
Leslie
- 512BB
Willem,
This picture is a correct AC Delco fuel pump, but these are no longer available, unless you find a new old stock or used item. They are out there.
There are more modern equivalents without the glass bowl, but I have never seen one like yours. As I said, if SJ sold it to you, I am sure it will work, but just does not look very period.
Leslie
Leslie
- 512BB
Sandals man wrote:......The barrel and olive (3x) of the vacuum adaptor are missing ,where can I get them? ......
Willem Holten
Willem
I dont believe the 3 way vacuum adapter is original as i have not seen one before on an Elan but I am not familiar with all the details and variations of the various Stromberg head versions. A hose and fittings specialist shop may have what you need for that particular adapter or it might be easier to source the original Lotus fitting that screwed into the inlet tract and typically just connected direct to the rubber vacuum hose that may then have connected to a plastic hose in the case of the head light vacuum system.
Users browsing this forum: lottex and 23 guests
