Lotus Elan
Help with Parts Identification
PostPost by: jackr » Thu Nov 27, 2014 6:17 pm
OK - Heres the story - I recently bought an S4 from the wife of the deceased owner with an installed engine (not tested yet), restored brake system & alot of parts (some Elan & some Europa & some ???). I've got the Bean & the R.D Ent. parts manuals but I'm still having problems identifying some parts (maybe some arent Elan??). In the attached pic for example I have what looks like 2 windshield wiper motors - which one is Elan? Any help on the other stuff would be greatly appreciated.
Jack
parts2.jpg and
jackr
First Gear
First Gear
PostPost by: trw99 » Thu Nov 27, 2014 6:38 pm
Jack, you really need a Parts manual and a Workshop manual, plus the Buckland book. Life will become a whole lot easier for you then.
PostPost by: billwill » Thu Nov 27, 2014 6:40 pm
Can't really see in that picture, but each door has a window moving motor, which was originally designed as a wiper motor of a different car, I think.
We have a parts manual here on the website in the Wiki, but Geoff has not yet made it official.
http://www.lotuselan.net/wiki/Category:Elan_Parts_List
PostPost by: Bud English » Thu Nov 27, 2014 6:49 pm
... and Ray's site here has that info as well. http://rdent.com/manuals/index.html
You'll also find him helpful if that stash of extra parts comes up short of a much needed piece. :wink:
Bud
1970 +2S Fed
"Every Lotus that an owner modifies makes yours worth that much more." - You're welcome!
Bud English
PostPost by: types26/36 » Thu Nov 27, 2014 6:58 pm
I think these are a few of your items.
1. bracket to secure 1a wiper motor.
2. dash air vent.
3. seat floor runners.
4. plate where steering column passes through bulkhead.
5. breather pipe (head to air box)
6. outer steering column grommet.
7. hand brake tree.
parts2.jpg and
types26/36
PostPost by: types26/36 » Thu Nov 27, 2014 7:18 pm
A couple more (guesses)
8. heat shield ....carbs/ engine mount or slave cylinder???
9. headlight relay.
10. spacer's (inside airbox to carbs)??
11. thought they might be where the seat frame sits on carpet ??
parts2.jpg and
types26/36
PostPost by: fasterbyelan » Thu Nov 27, 2014 8:01 pm
Another item on the left side is the steering column lower clamp (part of item 22 here - http://www.lotuselan.net/wiki/HB_-_Steering_-_Column). You will need the felt strip to go between it and the column when fitting.
And if anyone has a spare clamp please let me know as I need one!
Karl 8)
1970 S4 FHC SE
fasterbyelan
PostPost by: jackr » Thu Nov 27, 2014 8:12 pm
WOW Thanks Guys! (especially Brian)
Jack
jackr
First Gear
First Gear
PostPost by: rgh0 » Thu Nov 27, 2014 8:56 pm
My bet is most are Plus 2 door / window frame components mainly
PostPost by: Bud English » Thu Nov 27, 2014 8:57 pm
The two tubes in Brian's post above appear to be just like the tubes mounted in the door hinge area on a +2 to protect the door wiring.
Door tube 1.jpg and
They mount from inside the body with two screws.
Door tube 2.jpg and
Knowing Lotus they may be used for both purposes. :D
Edit: ...and while I was typing. :lol:
Bud
1970 +2S Fed
Bud English
PostPost by: types26/36 » Thu Nov 27, 2014 9:05 pm
I think you are right there Bud........I stand corrected :oops: ......most of it was just guesses anyway :lol:
types26/36
PostPost by: Europatc » Thu Nov 27, 2014 11:18 pm
Brian Im impressed and that doesn't happen often these days.
good call
Stuart
Europatc
PostPost by: fatboyoz » Fri Nov 28, 2014 3:04 am
Jack,
Parts 11, as shown in Brian's numbered photo, are the left and right, vertical water gutters from the A posts.
Colin.
types26/36 wrote:A couple more (guesses)
9. headlight relay.
'68 S4 DHC
fatboyoz
Users browsing this forum: Hawksmoor, Quart Meg Miles and 11 guests
