Diff
The differential is from Ford, called the 'English' differential, and was fitted to the Anglia, Classic, Cortina, Corsair, Escort and Capri. So only a few million were made!
Make sure you get the ratio you want. 3.77 :1 was the common fitting on the Elan and Plus 2, with 3.55 used on many of the S/E models, which gave slightly reduced revs for 'cruising'. Many of the smaller model Fords used a higher (numerical) ratio, with 3.9:1 being quite common. 3.54: 1 was fitted to many of the 'sporting' Escorts and are also quite easy to get hold of, and as quite a few Plus 2 cars have been broken for spares, there are quite a few 3.77 diffs around.
These guys know their stuff if you want one re-built, or ask Sue Miller / Paul Matty if they do an exchange service.
http://www.arrowautoengineering.co.uk/page4.htm
Mark Kempson
Mark Kempson
Kurt,
I'm a junk yard scrounger (and owner of many Lotus). The only U.S. delivered donors for the diff are Ford Cortina and Anglia's, which used 3.9, 4.125, 4.44. I have Hollander interchange manuals and can provide specifics as to which model had which ratio, if needed. Ford Capri's in the U.S., even the 1600 had a different axle. Pinto 1600 was also different. If you're looking for something beyond a Ford/Lotus housing, I can provide advice of what can be made to fit (without fiberglass modifications).
Vic
Vic
- Vic
Vic, I'm a junk yard scrounger myself though there aren't many left with the good old stuff that I like in these part's! I have some friends in Colorado [several] and might be bothering you for a visit later this summer. Won't be driving my Elan though.
Kurt
26/3754
Kurt
26/3754
- nomad
