Lotus Elan
Elan S2 restoration...
PostPost by: gino1 » Mon Jan 21, 2013 8:43 am
Hi All,
Yesterday I fitted the front headlight conversion, removing the standard pods.
From a previous resto I made up a template and retreived some scrap sheeting from a local boat builders yard and cut out the sections to bond.
I'm going to fit the 5 and 3/4" lights and not the 7" ones.
Here are some pics before and after.
Gino
Milano
Italy
2013-01-20 16.18.41.jpg and
2013-01-20 14.57.12.jpg and
2013-01-20 14.56.20.jpg and
1965 Elan S2 Roadster
1965 Elan S3 Coup?
1967 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1982 Lotus Esprit S3
1961 Ford Anglia
gino1
PostPost by: RedS4 » Fri Mar 29, 2013 3:53 am
How's the new light system coming along?
Evan J
Elan S4 FHC RHD 36/8569 AND Green S2 Elise..
RedS4
PostPost by: gino1 » Wed Apr 10, 2013 3:47 pm
Hi All,
Not had much time recently to work on the car due to work commitments but just finished fitting the roll cage before finishing the bodywork off.
I was finally able to fit the 26R type bumper properly but only after cutting it in two and re-stitching it back an inch wider :roll:
Gino
Milano
Italy
2013-02-10 12.41.40.jpg and
2013-04-07 19.16.26.jpg and
2013-04-07 19.04.34.jpg and
1965 Elan S3 Coup?
1967 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1
PostPost by: vstibbard » Fri Apr 12, 2013 10:00 am
Hi Gino, coming along nicely, who made you roll cage? Cheers
PostPost by: gino1 » Fri Apr 12, 2013 12:04 pm
I made the roll cage.
I bought the steel profile 3mm thick, had the corners properly bent, bought proper FIA joints and welded the lot up.
You can remove the whole thing, except for the lateral bars as they are now closed in the sill section, very easily.
Gino
Milano
Italy..
1965 Elan S3 Coup?
1967 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1
PostPost by: dougweall » Thu Jul 25, 2013 6:29 pm
Hey Gino,
It's been a while since we had an update + pictures from your latest creation, how is it going my friend ?
Hope it has moved along.
Doug.
dougweall
PostPost by: gino1 » Fri Jul 26, 2013 7:21 am
Hi Doug,
Very slowly at the moment as we've temperatures of up to 40? and it's just too hot.
I'm on holiday in a week's time and therefore I will dedicate a little more time, get some fans going and try to finish the bodywork off in time for september.
I will be posting some pics of the painted soon after.
Ciao
Gino
Milano
Italy
1965 Elan S3 Coup?
1967 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1
PostPost by: gordont » Fri Jul 26, 2013 10:08 am
Looking good Gino, I just had my 26r lights and covers installed, used the kelsport 5 3/4 plastic pods and pretty pleased w end result. Pics to follow. Also cv driveshafts now in, equally happy :)
Gordon
26/5416
gordont
PostPost by: gino1 » Thu Aug 01, 2013 1:33 pm
Hi Gordon,
I did the same on my S3 and it came out pretty well...I've bought the same stuff for the S2 restoration as well :D
Gino
Milano
Italy
HPIM1577-1.jpg and
1965 Elan S3 Coup?
1967 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1
PostPost by: gino1 » Thu Oct 03, 2013 4:02 pm
Hi All,
Started my engine rebuild...steel crank and forged rods and pistons going in :D :D
can't wait to try it out...
Gino
Milano
italy
IMG_20131003_000532.jpg and
1965 Elan S3 Coup?
1967 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1
PostPost by: oldchieft » Thu Oct 03, 2013 5:31 pm
Interesting engine, what bore stroke and cams are you running?
oldchieft
PostPost by: gino1 » Sun Oct 06, 2013 3:31 pm
IMG_20131005_171317_2.jpg and
I had this LA marked block in the garage and some +30 high compression pistons so I decided to use them for my S2 rebuild. I also had some 85mm Omega pistons but thought it a shame to bore out this block above FIA limits.
I am fitting a steel crank and forged rods. The Head has been rebuilt using some reprofiled racing cams. 8)
This is just a pre-assembly to see if everything is correct...I'll be taking the crank out again shortly to have it properly balanced together with the new flywheel and clutch plate.
I'm going to use some 45 webers and a close ratio gearbox..
I'll let you know how many horses when I get everything dynoed. :)
Gino
Milano
Italy
IMG_20131005_171430.jpg and
IMG_20131005_171335.jpg and
1965 Elan S3 Coup?
1967 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1
PostPost by: rgh0 » Mon Oct 07, 2013 2:06 am
Hi Gino
They look like pretty big intruders on the pistons. A 6mm high one gets you around 12.5 to 1 compression ratio. Those look like you will be well over 13:1 ? What fuel are you planning on running?
PostPost by: gino1 » Thu Jan 02, 2014 9:39 pm
Hi all..Here are some more pics from the ongoing resto which I am doing during my xmas hols...
Well I'm down to final preparation before the undercoat goes on and paying particular attention to:
The door aperture lines.
The hard top fit (bugger !) Tugging and pulling here and there I finally got the hard top to align properly with four bolts holding it down ; two behind the rear window arches and two on the corner edges where it locks into the windscreen frame (hole centres 40 x 40mm) No duck tape here.
The rear bumper, as when you fit the 26R arches the standard bumper is narrow and needs top be cut and opened up.
Well a few more days to go before going back to work so I think the next pics will be in undercoat or final colour (not decided yet !!)
Gino
Milano
Italy
Elan S3 Coup? 581.jpg and
Rear Bumper modification
Elan S3 Coup? 584.jpg and
No duck tape !!
Elan S3 Coup? 577.jpg and
Side view
Elan S3 Coup? 562.jpg and
Door lines
Elan S3 Coup? 568.jpg and
26R wheel arches Rear
Elan S3 Coup? 567.jpg and
26R wheel arches Front
Elan S3 Coup? 570.jpg and
Hard top corner bolts
1965 Elan S3 Coup?
1967 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1
PostPost by: gino1 » Tue Apr 08, 2014 1:31 pm
Hi all,
Working very late evenings to get the bodywork all done and final skim of filler going on before it goes to the paintshop.
Hardtop and bumpers already painted Opaque Silver.
Gino
Milano
Italy
IMG_20140405_181838.jpg and
IMG_20140407_212730.jpg and
IMG_20140407_212700.jpg and
IMG_20140407_212630.jpg and
1965 Elan S3 Coup?
1967 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1
PreviousNext
Users browsing this forum: checkrail, Foxie, pptom, snowyelan and 15 guests
