stainless steel fixings
I would be interested to know whether what I would term 'screw plates' for example the little items that receive the self tap screws behind the front side lights and used extensively throughout are still available and whether in stainless steel?
As a general question have others fitted stainless steel fasteners nuts/bolts/washers and have there been any negative results like becoming loose or shearing.
Finally the stockists who supply in small numbers in UNC/UNF and the self tap screws?
- richard sprint
Give "Namrick" a try, I know that they sell S.St. Fasteners in small quantities.
Due to the way they work, the trim "Nuts" are made from Spring steel sheet, some are Zinc plated which offers a bit of protection from corrosion.
I've never seen any made from S.St.
They are still widely used within the industry & are available in many designs & sizes.
Sorry cannot provide you with a specific source.
Beware of the Illuminati
Hi there
Assuming you're in the UK try http://www.namrick.co.uk
As far as the use of stainless steel fasteners goes, while high tensile ones are available, I wouldn't use them on anything critical.
I only ever use high tensile grade S (or better) nuts and bolts, zinc plated ones if appearance is important.
Andy
Andy
- andyelan
A few on ebay but none in stainless, (They are called Spire Clips)
http://shop.ebay.co.uk/i.html?_nkw=SPIR ... m270.l1313
Terry
Terry
- terryp
I've found these suppliers good for small quantities http://www.stagonset.co.uk/ + also worth looking on Ebay and searching for the specific size you need as the postage tends to be cheaper than the bigger suppliers - you can end up spending ?3 on postage for ?1 worth of small items
The other name for the screw fixings is speed nuts - I haven't found any in stainless.
Lotus Elan Sprint FHC 1973
RichardS - Fourth Gear
RichardS wrote:I've found these suppliers good for small quantities http://www.stagonset.co.uk/ + also worth looking on Ebay and searching for the specific size you need as the postage tends to be cheaper than the bigger suppliers - you can end up spending ?3 on postage for ?1 worth of small items
This link is now dead.
You are welcome to try our new company with the details below.
Jason
http://www.westfieldfasteners.co.uk
0845 527 9511
0845 527 9511
- westfieldfasteners
Also known as a Tinnerman fastener.... http://www.tinnerman.com/en/company/history.asp
Flat and several U type variations (with aircraft corrosion proofing) here: http://www.aircraftspruce.com/catalog/h ... nerman.php
Note the type B screw needed.
Jim
Jim
- spanner
I decided to use "rivnuts" which are large diameter soft rivets with a screw in the base. They are very neat, but in europe it is difficult to get anything other than metric sizes. They aren't stainless & I have a small concern that I will run into electrolytic corrosion problems in the future.
In the US they will be available in UNF/UNC/ANC I'm sure.
Geoff
Geoff
- The Cyclist
The Cyclist wrote:I decided to use "rivnuts" which are large diameter soft rivets with a screw in the base. They are very neat, but in europe it is difficult to get anything other than metric sizes. They aren't stainless & I have a small concern that I will run into electrolytic corrosion problems in the future.
I have used rivnuts in many places on my car - please explain how and where electrolytic corrosion can take place.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
bcmc33 wrote:I have used rivnuts in many places on my car - please explain how and where electrolytic corrosion can take place.
I don't know about these specific rivnuts but I think the poster was referring to corrosion due to direct contact between 2 different metals with an electrolyte (water/salt/etc) present. The rate of corrosion is proportional to the relative areas and the electric potential between the two metals, which of course depends on the metals involved.
Apologies if you're already aware, but metals are generally ranked according to their potentials in something called the Galvanic series http://en.wikipedia.org/wiki/Galvanic_series and to get a decent corrosion rate you generally pick one from the top, one from the bottom. For example, if you had a 316 stainless bolt and used an Aluminium nut, then you'd expect the nut to corrode quite badly. Guessing at the compositions of a rivnut with an aluminium "rivet" with either directly threaded aluminium or a threaded steel insert and using a steel bolt, then you'd expect corrosion at the Al/steel interface.
In practice this might be negligible because there are lots of mitigating factors to influence the rates - surface areas, constant/intermittent presence of electrolyte, simple protection with grease/waxoyl, etc.
UAB807F - Fourth Gear
And one can get s/s rivnuts too...In Imperial.
I personally don't bother and use metric s/s fasteners where appropriate. DO NOT use where high tensile is required. but where normal around the engine bay etc fasteners are concerned they are fine. And they polish up like chrome.
All the best guys...
Al' ......
Al' ......
Alex Black.
Now Sprintless!!
Now Sprintless!!
Love the thread drift.
I can't imagine that Spire clips (of whatever composition) would be used to fasten on anything "critical".
wrt the SS bolts supplied by Namrick, I did some non-scientific testing a while back vs "normal" mild steel items of the same sizes, using a vice and a torque wrench. The SS items are pretty tough! However, as previously posted, if HT bolts are specified, use HT bolts.
Pete.
http://www.petetaylor.org.uk
Pete.
Geoff
The thought of using aluminium rivenuts had never crossed my mind. When you do use these with steel screws/bolts always use lithium grease to prevent any reaction.
I use steel/stainless steel rivnuts from http://www.memfast.co.uk/ (no connection).
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
Just a thought on the use of Rivnuts.
Alex mentioned in an earlier post about using them on the gearbox cross member; a horrible thing to get at with spanners in situ'.
However that area is right down where corrosion can easily occur (well if you don't have a leaky Twincam)
I was wondering how Rivnuts would stand up in that environment or more precisely what would stop them turning with the bolt if they were corroded together?
Maybe a weld nut would be more appropriate in areas like that?
Users browsing this forum: Billelan and 40 guests
