Federal S4 with foglights?
My S4 has a different front light configuration and body than any other I have seen. Under the front bumper, the body has been reshaped to integrate fog lamps. Was this an option, or a PO going creative? Thanks. Dan
The fiberglass work is very well done, which is why I questioned if it was an option or an aftermarket kit. I'm considering either replacing these with round MINI foglights, because I really don't like the look of these rectangular ones or getting advice on how to go back to the original configuration, if its not too difficult. Dan
This is the exact same modification that was done to my Series 4 Sprint. I was told the previous owner had it done by the factory prior to delivery. Mine had Lucas Square 8s installed when I got it. The only problem was the Square 8s had a plastic housing, not the steel housing. It seems that the bulb generates enough heat to melt the housing if you forget to turn them off while sitting still. I guess there is no problem while moving to keep them cool.
- cbxbikenut
Users browsing this forum: philbirch and 42 guests
