Elan S4 1968 - Wiper switch wiring
I'm currently replacing all electrical wires and harnesses in my freshly rebuilt 1968 Elan S4.(Nr 45/7459). Everything works, but the wipers....And it's rainy here in Belgium....
Does somebody know how to connect the small 4 wires harness, coming from the wiper motor, to the wiper switch ?
The switch has 4 connectors :
1 2
3 4
and 3 positions:
Pos 0 links connectors 3 and 4
Pos 1 links connectors 1 and 4
Pos 2 links connectors 1 and 2
Wires colors are :
White/Light Green
Brown/Light Green
Blue/Light Green
Red/Light Green
Do i need to ground one of the connectors or the motor ?
Any information would be helpful.
Many thanks
Christian BRIOU
B-4122 Plainevaux (Belgium)
e-mail : ***@***.***
1 2
3 4
and 3 positions:
Wires colors are :
White/Light Green
Brown/Light Green
Blue/Light Green
Red/Light Green
Many thanks
Christian BRIOU
- "Christian BRIOU&quo
On my S4, 45/9536, the poles on the switch aren't numbered, but if you
look at it from the back of the switch and the upper left is pole 1, it
is the white/green wire, your pole 2 (upper right) is brown/green, pole
3(lower left) is red/green, and 4 is blue (I don't see the green tracer
on mine, but it could be there). Wipers were working fine on mine.
On Fri, 1 Dec 2000 19:27:30 +0100 "Christian BRIOU" <***@***.***>
writes:
________________________________________________________________
writes:
- david collier
I think that the motor is also grounded/earthed.
Gary
--- In ***@***.***, david collier <dacollier@j...> wrote:
Gary
and 3 positions:
Allows power for parking at slow speed
Slow speed
fast speed
Wires colors are :
White/Light Green
Brown/Light Green
Blue/Light Green
Red/Light Green
sorry can't help... all packed here
Yes thereshoud be a black wire from the motor. In traditional cars the motor is earthed through it's mounting. On some of the replacement motors and mounts the motor is isolated from the mount by rubber, this helps keep the motor noise down, but makes earthingis easier (as they have an earthing point on the motor)
Brin
Slow speed
fast speed
Wires colors are :
White/Light Green
Brown/Light Green
Blue/Light Green
Red/Light Green
Brin
- paul_adamson
