Bill - where did you find the number stamped into your chassis?
Who did you contact, and How long ago did you get copy of factory
records? Wonder if I can get for mine.
All I ever found on chassis is a big 3.7 in yellow paint on the rear
cross member. All my info is engraved with a vibrating marker on a small
aluminum plate with the lotus logo, sheet metal screwed to the left side
fire wall. My chassis No is 45/6078, unit #6078 M-27 Red. Engine LP
6561. I have had head off - never found head number, but on front of
head in black majic marker is 6078. Where did you find Head and engine
numbers?
Mine was sold to me new from dealer as a 1967, believe built in fall of
1966. I remember reading something in a car mag about Lotus holding
numbers in reserve - I thought because a certain number had to be
manufactured to be classified as a production vehicle. Also something
about they could never build/sell # held in reserve.
I think a lot of the cars were hastily put together with whatever was
around.
The original headlight relay on mine was a Lucas horn relay (they are
designed for short, intermittent duty) It started smoking about 15 min
after lights were turned on, burned out shortly thereafter. Body has
drillings for right hand drive that were filled in with gray epoxy. Have
seen other Elans produced around same time - different radiators,
Transmissions, rear axles, generators, starters, batteries (mine was a
small lawn tractor battery), heaters, even dashboards - mine is of very
high quality, veneered and sanded smooth on both sides, varnished on
front only. no cracks or delaminating after 30+ years, yet another car
made within months of mine had another type of material for the dash that
severely deteriorated within 5 years.
My power window motors are adapted windshield wiper motors that still had
the park switches on them.
on
On Mon, 29 Nov 1999 18:19:31 EST
[email protected] writes:
