Unleaded juice in a twink
Easy question for you guys, this. I would be very surprised if it
hasn't been discussed before, but it must have been before I joined the
list (August 1998). Apologies therefore for repetition:
My plus 2's twincam has a 1993 rebuilt QED big valve head, with colsibro
bronze valve guides. What else do I need to do to the head, and what
adjustments to the timing to I need to make to switch to unleaded?
I am aware that I should use "Premium" 98 octane unleaded, rather than
the standard stuff.
Alternatively, should I trust one of the emerging lead substitutes,
despite the fact that the BSi still haven't developed a British Standard
for these products?
5 months, 2 days to go!!!
Stephen
1970 Plus 2S
RPS Consultants Ltd
3 Linenhall Place
Chester
CH1 2LP
UK.
Tel +44 (0)1244 313486
Fax +44 (0)1244 317471
Part of the RPS Group plc - The Environmental Consultancy
This message is sent in confidence for the addressee only. It may
contain privileged information. The contents are not to be disclosed to
anyone other than the addressee. Unauthorised recipients are requested
to preserve this confidentiality and to advise the sender immediately of
any error in transmission. If you experience difficulty with receipt of
the email please telephone on 01244 313486 or fax on 01244 317471.
the standard stuff.
for these products?
Stephen
1970 Plus 2S
RPS Consultants Ltd
3 Linenhall Place
Chester
CH1 2LP
UK.
Stevie-Heathie - Third Gear
Stephen,
I'm in the same position, I think you/we will have to replace the valve
seats, the ones in mine aren't hard enough - just standard replacements.
Bronze guides should be ok. Sounds cynical, but I'm not going to pull the
engine apart until it shows signs of distress, I don't do any real mileage
and most times I'm not blasting along.
I was going to use a lead substitute/octane booster if the proposed LRP
isn't up to it. I hear about this LRP, but haven't seen any in a petrol
station around here (West Yorks) Anyone know what the octane rating will be
To all you guys in the US, etc, what do you do ? New valves/seats at
overhaul time ?
overhaul time ?
- BrianMartley
Brian Martley wrote:
Brian,
I live in California and have had numerous twink-engined cars, mostly Elans
and Lotus-Cortinas, currently with one running Elan.
We've had leaded fuel for a number of years now and I use lead substitute (STP
brand) now and then. The head is off now (water pump rebuild) and I see no
problems with the seats or valves. The car is a S1 but it has a complete
Sprint bottom end under the Weber head.
My gut feel is that lead substitute will be good enough until, as you
suggest, valve grind time when seats, guides and valves can be upgraded. No
problem with the last Lotus-Cortina I ran for regular use either.
I've had race cars also but the race fuel has lead and I used lead aviation
fuel anyway.
Rod Bean
Brian,
fuel anyway.
Rod Bean
rodbean - Second Gear
Rod,
Thanks for the info. Currently there's a lot of hype and debate over here
about additives, putting metal (tin ?) capsules in the tank/line, what does
work, etc, etc, so it's good to hear that the STP one looks to work.
To be honest, I'm more bothered about the octane rating, everything over
here seems to run on 2* - 95 I think - which I'm sure would upset the car
despite it's design.
- BrianMartley
I haven't had to add octane booster (do you have it?) on a stock, 9-to-1
compression ratio twink but it couldn't hurt, if you sense any detonation.
You can also retard the timing a bit if there is a problem. Or you can buy
some 100 octane race fuel and mix a little in every tankful.
Rod
Rod
Users browsing this forum: spridget and 13 guests
