steering rack height
• Page 3 of 3 • 1, 2, 3
Randall,
Which side is the passenger side or does the configuration change with
LH and RH drive?
Paul
LH and RH drive?
Paul
Randall Fehr wrote:
- "Paul Lane, Jr."
My farther in law runs a small engineering company and will make one / a set
for you.
Or even severalsets if several people want them.(That would make them a bit
cheeper)
He would need the dimensions and a worn one or an enginnering drawing.
this isn't a quote
If any one whan't his address or to persue this then send me an email.
Brian Scally
----- Original Message -----
To: <[email protected]>
Cc: : Randall Fehr <[email protected]>
Sent: Saturday, August 07, 1999 1:30 AM
Subject: Re: [lotuselan] Steering Rack Bronze bush
for you.
cheeper)
this isn't a quote
Brian Scally
- paul_adamson
-----Original Message-----
To: [email protected] <[email protected]>
Cc: [email protected] <[email protected]>
Date: 09 August 1999 09:23
Brian,
Thanks for your offer, but I already have facilities to a number of
machine shops. What I was looking for was off-the -shelf replacements (if
available), to avoid having to take the car off the road and remove the
rack and then wait for whatever time it takes to make up a replacement. I
find it saves a lot of unecessary work to draw on other people's experience
before getting stuck into the same work all over again.
Best wishes,
Sean Murray
Wexford
Ireland
1970 +2S
Heading for Austria in the Euroclassic in September !
Brian,
Best wishes,
Sean Murray
Wexford
Ireland
1970 +2S
Foxie - Coveted Fifth Gear
Sean,
Paul Matty (UK) recently refurbished a steering rack for me. They should be
able to source parts for you. In the alternative, try some of the Triumph
parts suppliers, like Revington and Moss Motors.
JAE (U.S.) <[email protected]> apparently also has parts for the Elan rack.
You might also try him if sources closer to home yield no results.
Andy
Andy
- abstamaria
Randall,
I have contacted Jeff at JAE, as you suggested. He indeed has the tie-rods
for the Elan at $34.00 each, and I have ordered a set. I had a difficult
time locating these (and I search worldwide!), so JAE may be the world's
only source.
You will recall I had to shorten my original tie-rods to fit the bent
steering arms for the larger front discs.
Thank you for the tip.
Andres
only source.
Andres
- abstamaria
The Elan tie rods as well as (early?) Esprit tie-rods had long been
unavailable so Jeff at JAE found a manufacturer and had them made. Keep
this in mind when you are told by a supplier that such-and-such a part has
long been unavailable, the next one you contact may have hundreds on the
shelf. Lotus parts especially for pre-1980s models don't all come from one
source, and the various suppliers don't share rolodexes. Even I reproduce a
few Lotus items and sell through some suppliers.
Randall
Randall
