Loose Flywheel
Again, not an owner yet of the Elan. But is it really true that neither
an access plate/dust cover nor sufficient access is available through
the starter hole to let you pry the thing and determine whether it's
about to fall off? If not, seems very odd... Not much access would be
needed for this level of assurance.
If you can't get at the flywheel, how do you guys read timing marks?
Tony's right that it fits the symptoms, but I hope for your sake he's
not on the money. running a loose flywheel is sure to make for some
nasty cleanup.
-- Doug Nicholls, 54/1822 Ma~
nasty cleanup.
- denicholls2
Yes..you can see the flywheel when you remove the starter. But what Roger
was referring to is the lower shield that covers the bottom 1/3 of the
flywheel. It is right behind the pan. On some cars..like my crossflow in
my seven?this shield is ?cut? in a manner that allows you to remove this
shield without taking off the top bell housing bolts and moving the engine
out about ? to clear the ,for lack of a better word that I cannot think of,
locating nipples?.or bushings.. I know on my early ?lans?.it was a solid
piece?like a BIG U.
You only see a small portion of the flywheel when you remove the starter and
it would be tough to get enough leverage to see if it was loose.
Tony
_____
Of Nicholls, Doug
Sent: Wednesday, September 13, 2006 6:18 PM
To: ***@***.***
Subject: [LotusElan.net] Re: Loose Flywheel
nasty cleanup.
piece?like a BIG U.
Tony
_____
Of Nicholls, Doug
To: ***@***.***
nasty cleanup.
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 05 Elise, 2005 MiataSpeed Turbo
tvacc - Coveted Fifth Gear
My S3 SS has a section of the shield that can be slid out easily by undoing 2 small set bolts, simple. I think some s4's had this as well.
Rodney Stevens
CSIRO Minerals
phone 02 9710 6701
Mobile 0432 506 427
Web: http://www.minerals.csiro.au/
Personal Web Page
http://mywebpage.netscape.com/rodjohnst ... mepage.htm
-----Original Message-----
From: ***@***.***lto:***@***.*** Behalf Of Tony Vaccaro
Sent: Thursday, 14 September 2006 10:02 AM
To: ***@***.***
Subject: RE: [LotusElan.net] Re: Loose Flywheel
my seven...this shield is "cut" in a manner that allows you to remove this
locating nipples....or bushings.. I know on my early ?lans....it was a solid
piece...like a BIG U.
Tony
_____
Of Nicholls, Doug
To: ***@***.***
nasty cleanup.
Rodney Stevens
CSIRO Minerals
phone 02 9710 6701
Mobile 0432 506 427
Personal Web Page
To: ***@***.***
Tony
_____
Of Nicholls, Doug
To: ***@***.***
nasty cleanup.
- Guest
Tony,
I think you are right about it being solid across the bottom on the early 4-bolt cranks, but the later 5-bolt crank engines I believe have a removeable piece at the bottom. And the car in question is a +2, so should have 6-bolt crank. Seems like I remember one of the 1/4 bolts holds a clip which anchors the clutch tubing. I think I was wrong about 4 -1/4" bolts, that there is only 2 holding on the removeable piece.
my seven…this shield is “cut??
- Elan45
Ah! maybe thats the noise.........the sixth bolt in a 5 bolt crank has
came loose!
Jokes aside, I don't think anyone has mentioned the possibility of a
cracked piston, it can happen and can make a loud thumping noise.
64Elan/72Sprint/Birkin T.C.Seven
came loose!
Gidday,
With a cracked or broken piston the noise is reduced or eliminated when cranking without plugs fitted.
See ya, Les.
----- Original Message -----
To: ***@***.***
Sent: Thursday, September 14, 2006 9:43 PM
came loose!
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.405 / Virus Database: 268.12.3/447 - Release Date: 13/09/2006
See ya, Les.
To: ***@***.***
came loose!
- lotuselanman
Hi Everyone,
Thanks again for the suggestions--sorry I haven't looked earlier--job
comittments taking up the time.
I have decided that the engine must come out this winter and am now
trying to track down an engine hoist and hope to be able to do the job
in about 3 weeks.
I know that you can see a bit of the flywheel when you pull the
started out so I might poke around there a bit as I have to pull the
starter out anyways to get the engine out.
Any advice about pulling the engine--I have never done this kind of
thing. A more experienced friend will help me but don't think he has
ever done it on a +2--baby Elan yes. Anything I should be on the look
out for?
Thanks again.
David
in about 3 weeks.
out for?
Thanks again.
David
- davidwinegar
--- In ***@***.***, "david_c_w" <david_c_w@...> wrote:
I must have missed an earlier post but did you confirm its a loose
flywheel?? If it is, I'm sure there'd be some funky clutch symptoms,
too. Just making sure its really justified.
Greg Z
'72 Sprint
Greg Z
'72 Sprint
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
Haven't confirmed the loose flywheel yet--I'm taking the engine out
next weekend and will update everyone at that time if I find
something. Even if it is not that, I think that the engine still must
come out for a rebuild--oil leaks are increasing and I can not be sure
what was done in the last supposed rebuild so it is best to take it
out and do it right now.
I will keep all up to date as to what I find.
David
David
- davidwinegar
